Trailer marker , turn signal and stop light problems,
Discussion in 'International Forum' started by Kanskane, Dec 22, 2015.
  1. Kanskane
    Kanskane Bobtail Member
    Apr 13, 2013
    12
    Thanks Received:
    5
    kansas city ks
    Hi, i have 09 pro star, my truck was sitten cpl months, yesterday when i hooked up a trailer, i noticed the trailer marker lights was not working, and i replaced the burned fuse, after i found on trlr both turn signals and the stop lights not working, i checked the all fueses are fine,there is no power coming in seven ways plug from truckside, except in trailer tail light and in abs pronge,,i open the circuit board @truck outside by steershaft there is no power coming for all three trlr markes,signal and stop light,,i also disconect the battery wires for 15 mins,
    Any help please..
  2. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,770
    Thanks Received:
    6,210
    Body controller will send power to trailer light relays in the fuse/breaker panel in front of the passenger seat. Those relays should click when the lights turned on, stop or signals activated. There are also breakers that supply power to those relays. Make sure you check all that.
    Kanskane Thanks this.
  3. Kanskane
    Apr 13, 2013
    12
    Thanks Received:
    5
    kansas city ks
  4. Kanskane
    Apr 13, 2013
    12
    Thanks Received:
    5
    kansas city ks
    Yes, i will tell my mechanic to check it again @ morning,, also one more thing i noticed ,when i turned on lights the powers is continues coming in abs pronge in 7 ways plug..
  5. Heavyd
    Feb 4, 2009
    7,770
    Thanks Received:
    6,210
    The ABS is full time power.
  6. Kanskane
    Apr 13, 2013
    12
    Thanks Received:
    5
    kansas city ks
    I got fixed this problem today ,, it was bad body controller,, i swoped with another truck,, now all lights,turn signals and stop lights working on trailer..:)
    Heavyd Thanks this.
  7. Heavyd
    Feb 4, 2009
    7,770
    Thanks Received:
    6,210
    Sorry to hear that. I was hoping for something cheap. Did you boost the truck or something before this all started?
  8. Kanskane
    Apr 13, 2013
    12
    Thanks Received:
    5
    kansas city ks
    Yes, today morning ,i took the to international dealer and they clear all active and inactive codes,but problem was still there, so i just swoped the body controller and everything start working,, now i will be try with another truck if bad controller works with that..otherwise i have buy another body controller.:(
  9. Heavyd
    Feb 4, 2009
    7,770
    Thanks Received:
    6,210
    Sometimes they do lose their programming and simply need to be reflashed.
  10. Kanskane
    Apr 13, 2013
    12
    Thanks Received:
    5
    kansas city ks
    How we can reflashed it ?
