Trainee help
Discussion in 'Questions From New Drivers' started by rcassidy, Mar 14, 2016.
  1. rcassidy
    rcassidy Bobtail Member
    Mar 14, 2016
    16
    Thanks Received:
    So I got my license a month ago and I'm currently a trainee for this company. Today I am in West Virginia on I-68 which is mountain terrain going up and down hills constantly. So anyways he refuses me to use the jake brake to slow the truck down. He told me it's useless when you have a load. He told me just to stab brake which eventually had me having to pull over cause I overheated the brakes. Anyways I want to know if this is true?
  2. Straight Stacks
    Straight Stacks Paper Cha$er
    Jul 18, 2015
    2,930
    Thanks Received:
    20,768
    Alabama Gulf Coast
    Your trainer is an idiot.
    mindes, Canned Spam, wore out and 22 others Thank this.
  3. HalpinUout
    HalpinUout Road Train Member
    Oct 2, 2011
    7,074
    Thanks Received:
    18,165
    When empty you shouldn't have to touch the brake if you got jakes
    CJndaTruck, austinmike, Grijon and 4 others Thank this.
  4. HalpinUout
    Oct 2, 2011
    7,074
    Thanks Received:
    18,165
    What company is this?
    Lepton1 and Mudguppy Thank this.
  5. Mudguppy
    Mudguppy Degenerate Immoralist
    Apr 28, 2014
    1,657
    Thanks Received:
    4,064
    Wooley Swamp
    NO. You're trainer's a jackwad.
    What company might this be?
  6. rcassidy
    Mar 14, 2016
    16
    Thanks Received:
    Western express
  7. Chinatown
    Chinatown Road Train Member
    Aug 28, 2011
    74,977
    Thanks Received:
    170,894
    Henderson, NV & Orient
    That is the correct answer.
    Use the jake brake or steady pressure. I never had a truck that the jake brake worked correctly so spent my whole career using "steady pressure" method and never had a fire or any other problems.
    I've caught a lot of grief about this method, but it works and works well. There's more than one way to skin a cat.
    I've been over all the steep grades all over the country and never had a problem with the "steady pressure" method.
    Lepton1 and Straight Stacks Thank this.
  8. sawmill
    sawmill Road Train Member
    May 29, 2015
    3,699
    Thanks Received:
    68,627
    Evanston, WY
    Turn the jakes on. Run slow enough in a low enough gear that you don't need to keep hitting the brakes to control the RPM. Don't let anyone passing you make you think you need to go faster.
    Oh, and punch your trainer in the throat. He's an idiot.
  9. Mudguppy
    Apr 28, 2014
    1,657
    Thanks Received:
    4,064
    Wooley Swamp
    I'm so sorry.....
  10. dca
    dca Road Train Member
    May 31, 2011
    6,834
    Thanks Received:
    11,427
    Earth
    regardless of what experienced gurus say there is a period during training where use of jakes is not allowed with many companies. it is part of the training
