transmission will not shift in to high side
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jakebrake13, Aug 18, 2008.
  1. jakebrake13
    jakebrake13 Bobtail Member
    Aug 18, 2008
    Thanks Received:
    IVANHOE, IL
    I have a 1996 pete 378 with a 3176 cat and a 8LL trans all of a sudden in will not sift to high side all it does is grind. removed all air lines to trans. and blew them out removed air cylinder on back of trans and clean resealed, also removed top cover and watched the gear cluster move seemed to engage and disengaged fine?? at loss is it time for new trans? any help would be great thanks
  2. SPIKE 64
    SPIKE 64 Light Load Member
    Feb 26, 2008
    150
    Thanks Received:
    27
    San Antonio tx.
    You cant see the rear section from with the top cover off, drain the oil and look for metal shavings, My buddy had a similar problem but it was'nt a 8LL,he had a 9 speed and ended up re-doing the rear section they found exsesive wear on the syncro.(cost him about $800 and a day to do it )
  3. 25(2)+2
    Sep 18, 2006
    18,750
    Thanks Received:
    45,476
    the road less travelled
    On the 8LL, if the shifter for the creeper gears gets partially engaged or out of adjustment, it will prevent you from shifting into the high side. Was it suddenly an issue, or did it come about gradually? I'm trying to remember what the switch looked like, I only drove one a couple times several years ago, but I had that problem, once.
  4. dray
    dray Bobtail Member
    Aug 12, 2008
    7
    Thanks Received:
    McDonough georgia
    sounds like the syncro in the back box
