Tripac apu problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mario 1156, Nov 15, 2015.
  1. mario 1156
    mario 1156 Bobtail Member
    Jul 15, 2010
    26
    Thanks Received:
    Miami FL
    Hi, i have a tripac apu. My heater was not kicking on, the apu was runing but no air was coming from the spar heater. after a while a decided to reprogram my display so it will show me internal temperature.
    And there was my problem. Even that is was very cold inside my truck, the display show is was 125 degrees inside. my heater was set to 90 degrees.
    My question. How can i reset the thermostat inside my truck?
  2. mario 1156
    Jul 15, 2010
    26
    Thanks Received:
    Miami FL
    I found the problem i program it to optional control temperature.
  3. slavcha
    slavcha Light Load Member
    Oct 17, 2011
    151
    Thanks Received:
    133
    Utica NY
    Sure it's 125 degrees inside, you in Miami.
  4. brian starr
    brian starr Bobtail Member
    Jan 27, 2016
    Thanks Received:
    hi my apu comes on just blows cold air .is there a valve in need to on plz help froozeeeeee in mi
  5. bavarian
    bavarian Heavy Load Member
    Feb 13, 2014
    729
    Thanks Received:
    783
    Winnipeg
    You sure have it on heat?
    I got the system explained once from a TK tech.
    For the heater, you set the temp on the display. But the heater has the tempsensor internal and reacts when the temp drops below set temp and fires up.
    The A/C has no internal sensor. It's the little pin on the display.
