Hello forum. My Volvo 780 (2008 780 D13) just shut off on me while I was driving. Won't turn back on. Only code I get is MID 128 SD 39 FMI 0. Can't find anything online regarding that code. Would really appreciate any help! Trying to find a shop online around here but trying to see if I can get truck turned on so I can drive it to the shop.
Will it crank. Yes means a sensor shut it down. No means it might be something prevent it from starting. Maybe battery or charging system. Low antifreeze will shut down a truck too. Find water to add.
MID 128 is an engine code. SID 39 is for the starter motor relay. FMI 0 means "Data Valid but above normal operational range".
Same thing happen to me Saturday night (03 May 2014) I 90 Exit 29. Towed to Exit 35, Volvo dealer close on Sunday, I check all the in dash fuses all working, I check the Batteries and found a bad 30 amp fuses replaced cleaned the batteries truck started up.
