Truck on runs when key is turned to on/start position
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by SeawrightFreight, Apr 24, 2018.
  1. SeawrightFreight
    SeawrightFreight Bobtail Member
    Dec 14, 2017
    4
    Thanks Received:
    Atlanta, GA
    I have a 2006 Freightliner Columbia Detroit 60. This truck will not stay running unless the key is held in the on position. Once i let the key go the truck shuts off. Fires up no problem. Could it be a fuse? Ignition? Starter? Fuel pump? I have no idea. Any advice?
  2. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,783
    Thanks Received:
    6,220
    Ok, need to understand this better. Are you holding the key in the "start" position and then when you release it to the "run" position it stops? If so you are forcing the starter to stay engaged and this is what is turning the engine. You will burn your starter out in no time. If the engine is properly firing and dies when you release the key switch, it might be just a bad ignition switch.
    little cat 500 Thanks this.
  3. sergk1989
    sergk1989 Bobtail Member
    Jan 23, 2013
    39
    Thanks Received:
    10
    What was the problem, my truck is doing the same. Already put new ignition switch
