truck wandering
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 377pete, Jan 27, 2011.
  1. 377pete
    377pete Light Load Member
    Oct 26, 2009
    147
    Thanks Received:
    14
    dfw
    we replace kingpins on my freightliner tuesday becouse it would pull you to the sides wich ever way you where going. they had alot of play now they are tight and can feel the difference on the road. But know you hold the steering wheel and truck will wander from side to side. tires are a week old all 10. tie rods look shot as the boots are tore looking. could it be them? previous tire where wearing even and so are the new. or can it be a tire balance problem becouse i can feel the drivers side wheel shake
  2. Flying Finn
    Flying Finn Heavy Load Member
    Jun 22, 2010
    972
    Thanks Received:
    558
    Ontario, Canada
    If the tie rod end boots are torn you can bet they are worn beyond healthy. Best get them replaced before one falls right off and you have no control as to where you are going at all.
  3. JohnP3
    JohnP3 Road Train Member
    Feb 21, 2010
    1,594
    Thanks Received:
    684
    Rock Creek B.C. Canada
    You can check the tie rod ends, your self, on the left side, you just hold the steering shaft, and twist it back and forth, put your finger on the joint if it has and slack it is junk, get someone to do it, to check the right side one. You do not need any force to feel the slack.
    If you did the king pins the front wheel bearing are good. Jack up the rear axles and check the rear wheel bearings, and the bushings in the end of the springs, and check the "U" bolts. Hit the "U" bolts with a hammer and they should ring, thud and they are loose.
    You may want! AFTER you fix everything that has slack, get a full front and rear alignment.
  4. CATshaker
    CATshaker Bobtail Member
    Sep 25, 2010
    35
    Thanks Received:
    Rushville, IN
    check to make sure wheel bearings are torque to the proper spec,,, i had the same thing on my driver steer... it was shimming ,,
  5. Joew900
    Joew900 Light Load Member
    Nov 23, 2009
    54
    Thanks Received:
    17
    If you installed the king pins to tight "you" could be doing the wandering by over steering. When the truck drifts you turn the steering wheel to correct and if the king pins are tight they bind and you turn the wheel harder, and then your over steering and then your turning the wheel back the other way to again to compensate and with the binding you over compensate again without realizing your doing the wandering and not the truck. I hope this makes sense and helps you out.
  6. 377pete
    Oct 26, 2009
    147
    Thanks Received:
    14
    dfw
    got it fixed...replaced the tie rods and know its all good. just need to balance front steers now. thanks every one
  7. rickybobby
    rickybobby Road Train Member
    Jul 10, 2010
    4,843
    Thanks Received:
    6,672
    greensboro, nc
    How much did it cost for th tie rod and labor?
  8. Ashman_42
    Ashman_42 Light Load Member
    Aug 14, 2011
    248
    Thanks Received:
    64
    New tires can cause this, I installed Dunlop 881's on one of my units and the same thing, truck was line to line and horrible on curves, so I swapped tires to a different unit and the problem also followed to that unit. Tire shop said to break tires in for 2 weeks and the problem went away.
  9. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,826
    Thanks Received:
    6,276
    I would recommend replacing both ends. I would also look into replacing the whole tie rod bar with new ends. We are finding it is actually cheaper to get the new bar complete with new ends vs just the ends separately. It is also faster to change the complete tie rod bar as an assembly vs one end separately because your not fitting with turning out a seized tie rod end.
  10. Scrapper
    Scrapper Light Load Member
    Jan 19, 2010
    289
    Thanks Received:
    83
    Nashville, AR
    Heavy is right...a seized tie rod end makes a good day turn bad quick...have to heat with a torch....sometimes. I know you fixed it...but talking about front end stuff...Watch those u-joints on your steering shaft close. They will get play in them and you won't realize it. Can be easily overlooked. Grab the shaft like was said earlier to check tierod ends and be easy. Sometimes it takes a light hand to feel. Turn back and forth and push foward, backward, up, and down. Listen, feel, and look....ecspecially the one up by the firewall...it can be ellusive. Just something else to watch.
