Turning a fixed tandem axle to a spread axle
Discussion in 'Ask An Owner Operator' started by PacManTrap, Feb 5, 2016.
  1. PacManTrap
    PacManTrap Light Load Member
    Jan 29, 2016
    112
    Thanks Received:
    120
    Maryland
    I have a 2014 53' Utility Dry Van. I wanted to turn it into a spread axle dry Van. Has anyone ever done this? Also can you recommend anyone to do it in the Maryland area?
  2. baha
    baha Road Train Member
    Jul 25, 2013
    4,137
    Thanks Received:
    2,836
    ga
    Is the trailer spring ride or air ride now?
    Dominick253 Thanks this.
  3. spyder7723
    spyder7723 Road Train Member
    Mar 31, 2013
    15,471
    Thanks Received:
    25,075
    sarasota, fl
    I took a sliding tandem and made it into a spread. A fixed can't be much more difficult. Just a matter of buying the suspension parts and brackets and breaking out the welder.
    Dominick253 and PacManTrap Thank this.
  4. PacManTrap
    Jan 29, 2016
    112
    Thanks Received:
    120
    Maryland
    Ok thanks. I'll probably turn it into a sliding spread axle. I was going to do an independent spread but I've heard a lot of ad things about them
  5. areelius
    areelius Light Load Member
    Nov 9, 2012
    270
    Thanks Received:
    119
    Temecula Ca
    I run a 53 van too. What advantage is it to make it a fixed spread? Wont the tire scuff a lot??
    PacManTrap Thanks this.
  6. cnsper
    cnsper Road Train Member
    Feb 28, 2014
    5,869
    Thanks Received:
    27,421
    Some states you can haul more than the 80k while in others if you are loaded heavy on the trailer you can roll with it. You can go to 40k on a spread vs 34 on a tandem.
  7. PacManTrap
    Jan 29, 2016
    112
    Thanks Received:
    120
    Maryland
    Not if Yu put a lift axle on the front axle. You can lift it off the ground when making sharp turns
    areelius and Dominick253 Thank this.
  8. spyder7723
    Mar 31, 2013
    15,471
    Thanks Received:
    25,075
    sarasota, fl
    A rear axle dump serves the same purpose and is a fraction of the cost. 200 bucks vs 2500. To ideally you want both. The ability to lift the front axle when you don't need it for weight purposes greatly reduces rolling resistance for efficiency, and obviously reduces tire wear.
  9. spyder7723
    Mar 31, 2013
    15,471
    Thanks Received:
    25,075
    sarasota, fl
    Yep. To add to this, a spread makes it almost impossible to load a wagon wrong. The only time i worry about weighing is if i think i may be over gross.
  10. mslashbar
    mslashbar Medium Load Member
    Jul 22, 2009
    601
    Thanks Received:
    808
    elizabeth,co
    This is true if the loader has half a clue to what he is doing. Its very easy to be over on the drives if loaded wrong.
