Ultrashift (freightliner smartshift) Not going into gear after clutch replacement
Discussion in 'Freightliner Forum' started by Catliner, Oct 24, 2015.
  1. Catliner
    Catliner Light Load Member
    Jan 5, 2014
    164
    Thanks Received:
    39
    Thompson, GA
    I bought a Freightliner Columbia with a bad Headgasket, Its an MBE4000 (I know its a terrible engine to many) and the Eaton Ultrashift 2 pedal. Anyway instead of reparing the heads I just changed the engine as I had a complete take out with 95k miles. I installed the new engine, started it up and went to place it in gear, it jumped into gear but then jumped out within a fraction of a second and threw a code ECU130 on the insturment panel display. I didnt remove the transmission durring the swap, I did put a new DM Centrifical Clutch in durring the swap so I didnt have to remove it twice. The problem is that it wont go into gear, It tries once after start up but after that it changes from N to F1 to F2 to R on the gear selector display in the dash like its lost its mind..
  2. AModelCat
    29,147
    Thanks Received:
    158,406
    Did it shift before the engine swap? Did you replace the engine with the same brand and model?
    Catliner Thanks this.
  3. QUALITYTRUCK
    Jun 14, 2009
    1,804
    Thanks Received:
    1,765
    romulus,mi
    The new engine ecm has to be programmed for an automatic transmission to work correctly.
    flood and AModelCat Thank this.
  4. Catliner
    Jan 5, 2014
    164
    Thanks Received:
    39
    Thompson, GA
    Im using the old ECM on the new block. Transmission code is 27. Replaced the engine with an identical MBE4000. I dont have any idea if it worked when the old engine blew. The previous owner is unreachable
  5. flood
    flood Road Train Member
    Dec 25, 2010
    4,161
    Thanks Received:
    4,031
    you'll need to call the dealer to find out for sure what the code is
    but if I remember right ecm130 is the Message Identifier for the Transmission
    the instrument cluster is not seeing the transmission control module
    you may need to be towed to a dealer to have the dash, ecm, or trans reflashed
  6. Catliner
    Jan 5, 2014
    164
    Thanks Received:
    39
    Thompson, GA
    Code 27 is clutch related. Maybe the clutch needs recalibration after I installed it with the engine.
    flood Thanks this.
  7. Bonafide
    Bonafide Bobtail Member
    Oct 25, 2015
    Thanks Received:
    Engine must be revved up over 1500 rpm to unlock new clutch. Code 27 means that the clutch is locked up so the trans input shaft is turning and it wont go in gear.
  8. baha
    baha Road Train Member
    Jul 25, 2013
    4,137
    Thanks Received:
    2,836
    ga
    Are the u shaped hold down clips still in pressure plate , look in insp. plate under trans. and look when clutch is pushed to floor to see if pressure plate is moving all the way back out if not the clips that came on pressure plate can be pry out if they wont fly out with clutch press in at 1500rpm, also ck if main shaft is being stopped from turning by clutch brake?
  9. Catliner
    Jan 5, 2014
    164
    Thanks Received:
    39
    Thompson, GA
    Called eaton. The clutch is not unlocking. Gotta pull it out again
  10. Catliner
    Jan 5, 2014
    164
    Thanks Received:
    39
    Thompson, GA
    Its a two pedal
