volvo D12c 340 to 380
Discussion in 'Volvo Forum' started by ah fai, Dec 5, 2012.
  1. ah fai
    ah fai Light Load Member
    Aug 21, 2012
    178
    Thanks Received:
    Need some Help..
    I try to replace volvo fm12 D12C 340 to D12C 380, the engine look good when start at idle speed, but after a period of time the engine change to like missfire, lot of black smoke, the engine vibrate and comes with fault codes injector 2,3 unknow fault.
    and my question is for both of 340/380 engine
    - Are the fuel pump same?
    - Fuel overflow valve?
    - Fuel Pressure in fuel rail ?
  2. Pablo-UA
    Pablo-UA Road Train Member
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    D12C were supplied with Bocsh and Lucas injectors. They are not interchangable. So check for fuel injectors coding in ECM and remove cyl head cover to learn what injectors are installed.
    On US market over 90% trucks got Lucas (Delphi) injectors, on EU market a half were Bosch
  3. ah fai
    Aug 21, 2012
    178
    Thanks Received:
    ic, can i just reprogram the coding with volvo ptt techtools..?
    thanks in advance..
  4. masimo
    masimo Bobtail Member
    Dec 6, 2012
    Thanks Received:
    OFF topic: Ah Fai are you Chinese and possibly from Anhui Province?
    Sorry, can't send pms with 0 posts.
    Mike
  5. Pablo-UA
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    no, you cant, totally different fueling map.
    Only flash change
  6. ah fai
    Aug 21, 2012
    178
    Thanks Received:
    no, i am from malaysia.
    means i have to replace along with the injector.
    thanks Pablo..
  7. Pablo-UA
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    yep, it is easy solution. If it is not possible I have to desolder memory from ECM to change maps
  8. ah fai
    Aug 21, 2012
    178
    Thanks Received:
    can u do that ?
  9. Pablo-UA
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    I can, but I'm too far and it would be too expencive with shipping
    what injectors do you have? Bosch ore Lucas?
  10. ah fai
    Aug 21, 2012
    178
    Thanks Received:
    ic,
    it delphi,
    today i replace with delphi injector and look good, but the engine idling only 1500rpm when the truck is on road..
