Volvo D13 Rpm fluctuate during idle when engine temp cold
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by aman0182, Mar 10, 2019.
  1. aman0182
    aman0182 Bobtail Member
    Mar 10, 2019
    5
    Thanks Received:
    Any help with this issue ,I have Volvo d13 2013 HP475 ,Engine hours 12100 mileage 427500 . Its RPM fluctuate whenever i restart it after one or two hour shutoff . It makes sound like some kind of pump running behind it during this process .it does it for 10 to 15 mins, mostly depends how cold is engine temperature . when temperature goes up to 130 F-140 F , RPM goes to normal . During this RPM fluctuation exhaust through steam or fog kind of smog. Any body can help what is causing this or it is normal ? Truck has new injectors , New def filter, SCR Catalyst , almost has new emission . Does this causing Engine coolant temp sensor or something else going in it ?
  2. Newto Trucking
    Newto Trucking Medium Load Member
    Dec 26, 2013
    359
    Thanks Received:
    225
    NE Illinois
    Something like this
  3. aman0182
    Mar 10, 2019
    5
    Thanks Received:
    yes same issue ..i have video but i could not upload . does it normal ?
  4. aman0182
    Mar 10, 2019
    5
    Thanks Received:
  5. Newto Trucking
    Dec 26, 2013
    359
    Thanks Received:
    225
    NE Illinois
    Your problem is different from the previous video. It’s not normal, you might have a faulty boost pressure sensor or it could be your turbo VGT having issues. You need Volvo software to see what sensors are reading and go from there
  6. aman0182
    Mar 10, 2019
    5
    Thanks Received:
    Thank you for the information.
    Newto Trucking Thanks this.
  7. Génesis780
    Génesis780 Bobtail Member
    May 8, 2020
    Thanks Received:
    We’re you able to fix this issue on engine please post what was repair to fix the rough idle
  8. Kennyuscg
    Kennyuscg Bobtail Member
    Oct 31, 2016
    Thanks Received:
    I have the same exact issue and my truck idles the same as the second video. Once it warms up it normalizes and truck runs perfectly fine.
    I’m wondering what kind of repair aman0182 did to fix this problem? My boost pressure sensor in new and no fault codes are showing when I brought my truck to my repair shop to get diagnosed. Even my shop doesn’t know what to do.
    Any experts or truckers who had fixed this kind of problem? Any help is much appreciated.
  9. Rajatoor
    Rajatoor Bobtail Member
    Mar 19, 2019
    15
    Thanks Received:
    6
    Did you find the issue on your truck, i got the same problem
  10. The_Truckr
    The_Truckr Bobtail Member
    Sep 30, 2011
    7
    Thanks Received:
    Artesia,CA
    I had this issue an for me it was the turbo vgt I replaced it an the turbo an problem went away.
