Volvo I-Shift low rpm 10,11,12 gear problem NO CODES see video
Discussion in 'Volvo Forum' started by RGZ, Oct 24, 2019.
  1. RGZ
    RGZ Bobtail Member
    Oct 23, 2019
    4
    Thanks Received:
    Please see video
    It’s Volvo 2014 560 000miles
    I have problem in upper gear 10,11,12 when is low rpm ( you can see in videos what’s happening when I’m going uphill without load... you can hear the noice in 11 and 12 gear and it’s looking like the engine cutting power).
    There is no codes and errors when is truck plugged in to computer.
    Mechanic change injectors, clutch and clutch cylinder, fuse box. Mechanic check all codes and computer is showing that is everything normal.
    is anybody had similarly problem?
    Thank you for help and answer
    Best regards
    KB3MMX Thanks this.
  2. Bakerman
    Bakerman Road Train Member
    Jan 27, 2013
    4,663
    Thanks Received:
    8,812
    Phoenix, AZ
    Yeah, I hear that I shift is pretty nifty……………… When it’s working.
    with the engine and transmission talking to each other and computers controlling everything, I don’t think you can diagnose it without plugging it into a computer.
    someone can correct me if I’m wrong.
    start with the obvious first, did you check the fluid level?
  3. rbrtwbstr
    rbrtwbstr Road Train Member
    Jul 11, 2012
    3,391
    Thanks Received:
    7,870
    in the bush somewhere
    Just a thought, but maybe something electrical. Bad ground wire somewhere causing loss of electrical power to the transmission controller?
  4. nasriza
    nasriza Road Train Member
    Feb 1, 2013
    2,398
    Thanks Received:
    2,074
    Chicago, IL
    Need to pull and see if there is any sort of codes this could be a few different things, even parameters set up could cause the rpm like this, noise thats a different story.
    KB3MMX and QUALITYTRUCK Thank this.
  5. nasriza
    Feb 1, 2013
    2,398
    Thanks Received:
    2,074
    Chicago, IL
    Do you know if you have a kick down option on your trans or premium shifter, i shift has a problem rpm for down shift its to low and if not programed with the other two options makes for very pain in the ### driving specially on hills, second thing you need to check is also check make sure your leveling valve is working properly and keep the airbags at the right level
    QUALITYTRUCK Thanks this.
  6. RGZ
    RGZ Bobtail Member
    Oct 23, 2019
    4
    Thanks Received:
    So... I brought truck to Volvo and they did some test and they told me that 3injectors doesn’t work...
    Week ago other mechanics replaced all injectors and it didn’t solve problem...
    Is it possible that these mechanics did bad job or they didn’t replace injectors or what ?!
  7. Volvo2014vnl
    Volvo2014vnl Bobtail Member
    Nov 3, 2021
    Thanks Received:
    Did u find out solutions please let me know
  8. 05vnl670
    05vnl670 Light Load Member
    Feb 17, 2013
    165
    Thanks Received:
    60
    I had a problem that I thought the truck didn't have power in low RPMs and was developing vibration and the only solution was to downshift manually but then it seem like the RPMs were too high, replacing all 3 engine mounts solved the problem, 2014 Volvo d13 with ishift I had about 460k miles at that time. A year later still runs fine.
  9. famykool
    famykool Bobtail Member
    Jul 22, 2008
    9
    Thanks Received:
    Union City
    was it any particular gear that you felt the vibration in? I am having trouble when loaded heavy, uphill, when it goes from 12 to 11th gear around 50 mph, it starts to vibrate. The humming of the engine starts going in and out as if it is cutting out but the rpm needle doesn’t drop or fluctuate with the sound.
  10. Stringb8n
    Stringb8n Road Train Member
    Sep 27, 2015
    1,698
    Thanks Received:
    2,219
    Did you ever figure your issue out?
