Volvo Throttle Response loss in turn at low speed or from a stop.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rhitrucking, Jan 3, 2019.
  1. rhitrucking
    rhitrucking Light Load Member
    Feb 7, 2017
    163
    Thanks Received:
    72
    I have an issue with the Volvo VNL. If I am trying to make a turn from a dead stop or low speed, I lose throttle response midway through the turn. Once the steer wheels are close to straight, all is fine again. No lights on the dash come on. No issues when driving otherwise. I do have a brake fault MID 136 SID 69 FMI 2. Not sure if its related or not. Any help is greatly appreciated. 2011 Volvo
  2. stillwurkin
    stillwurkin Road Train Member
    Dec 2, 2017
    1,756
    Thanks Received:
    2,856
    Since no one took a stab at this..i don't know about the codes. But, does it matter which way you are turning? Turning puts a sort of twist on cab and truck. Could be a wire somewhere slightly rubbing. Or a throttle sensor on your accelerator. But woud think it would act up going straight or turning.
  3. rhitrucking
    Feb 7, 2017
    163
    Thanks Received:
    72
    It does it regardless which way I am turning. It has to be a turn from a dead stop or very low speed. I get halfway through the turn and lose throttle response until the steer tires are closer to straight, then all is fine. I am thinking it has to do with the steering angle sensor not playing well with speed sensors.
  4. stillwurkin
    Dec 2, 2017
    1,756
    Thanks Received:
    2,856
    Not sure about steer angle sensors. Mayby stop at a volvo shop and speak with the shop manager. You may luck out and find a decent guy that will give you a few minutes to discuss this crazy issue. I have done this, and i try to make it brief and polite . Some will and some won't but keep trying, mayby at another shop as time allows.
  5. shogun
    shogun Road Train Member
    Jan 23, 2009
    6,075
    Thanks Received:
    72,159
    Doing a regen
  6. nasriza
    nasriza Road Train Member
    Feb 1, 2013
    2,397
    Thanks Received:
    2,070
    Chicago, IL
    Yes most likely steer Angle sensor is acting up the code is actually for load sensor. You need to move steering wheel to replace and also need to program
  7. rhitrucking
    Feb 7, 2017
    163
    Thanks Received:
    72
    where would one find the load sensor? I assume its behind the kick panel?
  8. nasriza
    Feb 1, 2013
    2,397
    Thanks Received:
    2,070
    Chicago, IL
    Behind clutch panel follow purple hose from the outside it’s should t off to two sensor from outside right on firewall it’s a 1/4 hose
  9. rhitrucking
    Feb 7, 2017
    163
    Thanks Received:
    72
    I got a CR-HD which live reads brake data. It turns out my right steer wheel sensor is giving no data. all others fluctuate with speed on the graph except one. My steering angle sensor appeared to be working correctly.
