Volvo - What does VCB stand for?
Discussion in 'Volvo Forum' started by Carport, Dec 3, 2014.
  1. Carport
    Carport Bobtail Member
    Nov 23, 2014
    22
    Thanks Received:
    Please anybody explain me that What VCB stands for? and its function on D12C. It is on top of engine between injectors. If it fails engine turned off or not? Does it manage injectors? Any ideas would be really appreciated
  2. KW Cajun
    KW Cajun Road Train Member
    Apr 12, 2013
    2,383
    Thanks Received:
    3,652
    Copperhead Road
    I only know it to be a Volvo Compression Brake, hence the "VCB", which is Volvo's engine brake.
    I believe it is 1/2 of the system and interacts with a "VEB" (Volvo Exhaust Brake), but others here that specialize in Volvo may be able to help beyond this basic info.
  3. nasriza
    nasriza Road Train Member
    Feb 1, 2013
    2,398
    Thanks Received:
    2,074
    Chicago, IL
    It's volvo compression brake and I f it fails it will not shut off a engine I n most cases Unless the solenoid or the housing breaks it's does you're second stage of engine braking first stage is is behind turbo don't try to remove and leave off cuz u will have low oil psi of physical re moved
