Vovlo Turn Signal Clicker
Discussion in 'Volvo Forum' started by AlexD13, Feb 5, 2021.
  1. AlexD13
    AlexD13 Light Load Member
    Jun 13, 2016
    298
    Thanks Received:
    85
    Hi Guys, The Turn Signal Noise died on me today. The turn signals still work, but the clicking noise does not come from the cluster. Any ideas on how to fix?
  2. thetransporter123
    thetransporter123 Bobtail Member
    Jan 5, 2013
    22
    Thanks Received:
    12
    Hope fully your low air warning still works, if it doesn't, then speaker in your dash just went on vacation and won't be coming back. Replacement speaker is only 25$ or so on amazon and you can solder it yourself if you have some soldering knowledge. If not , you can always get some to do it for you, but dealer will tell you it is not replaceable. Therefore will try to sell you 1500$ instrument cluster panel. Or other option is buy used from wrecker but will have to get all info transferred from old cluster panel to new one, then again more costs.
  3. AlexD13
    Jun 13, 2016
    298
    Thanks Received:
    85
    nice thanks for the info. I am gonna order it and try to do it myself.
  4. AlexD13
    Jun 13, 2016
    298
    Thanks Received:
    85
    supposedly mechanic says that my model, 2012 does not have the option to change speakers
  5. Weiboy718
    Weiboy718 Bobtail Member
    Jan 25, 2017
    47
    Thanks Received:
    34
    it absolutely does, how do I know? Because I have an 2012 and changed it myself.
    Tanin Auto Electronix Speaker Replacement | compatible with 2003-2008 Audi A4, S4 & A6 and Volvo VNL Semi Truck | Instrument Cluster Chime/Buzzer https://www.amazon.com/dp/B01J6HEDLO/ref=cm_sw_r_cp_api_glt_fabc_G760NVRN0NNH5XFR86K3
  6. AlexD13
    Jun 13, 2016
    298
    Thanks Received:
    85
