W900 frame horn and front spring hanger
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by W923, Feb 20, 2023.
  1. W923
    W923 Road Train Member
    Feb 28, 2022
    1,334
    Thanks Received:
    4,066
    Does anyone know if there’s a difference between frame horns and the front cast spring hangers on w900 trucks from the 80s? Asking because I’m thinking about upping the front axle to a 20k from a12k. I think I have seen some w9 s where the frame horns are doubled but I can’t recall seeing different from cast hangers other than some are iron and some are aluminum but don’t believe there was any correlation to the weight rating.
  2. Inderjit
    Inderjit Heavy Load Member
    Sep 17, 2017
    723
    Thanks Received:
    708
    I believe you are correct on the cast brackets. A Kenworth W900 with a 12000 or 14000 lb front axle would come from the factory with a HFB64 steering gear. If the truck was fitted with a 16000 lb axle it would have a HFB70 series steering gear. The 18000 lb front end came with the HFB70 gear and a steering assist cylinder on the right side. The a 20000 lb front end came with dual steering boxes a HFB70 on the left and a 64 series on the right side.
    You could order a Kenworth with the lighter axle and the bigger steering gear and Sheppard steering was also an option.
    Oxbow Thanks this.
  3. W923
    Feb 28, 2022
    1,334
    Thanks Received:
    4,066
    I don’t know what all you might have access to but is the front spring hanger (casting) considered part of that steering gear or are they talking specifically about the steering box and associated moving parts?
  4. Inderjit
    Sep 17, 2017
    723
    Thanks Received:
    708
    The front castings/brackets have threaded bosses where the steering gear/box mounts. Not all right side
    castings/brackets had a provision for mounting a steering gear.
    Oxbow Thanks this.
  5. W923
    Feb 28, 2022
    1,334
    Thanks Received:
    4,066
    That’s only the back mount though correct?
    The one at the very front of the truck on the horn never carries a box on a w9 to my knowledge… please correct me if I’m wrong
  6. Inderjit
    Sep 17, 2017
    723
    Thanks Received:
    708
    That is correct I was confusing the T800 steering gear mounting.
