w900a manual to air/power window conversion questions?
Discussion in 'Kenworth Forum' started by flc120, Jan 28, 2015.
  1. flc120
    flc120 Heavy Load Member
    Jul 11, 2012
    916
    Thanks Received:
    122
    Miami,FL (yeah i know :( )
    well just like the title states is there a universal kit that anyone sells t odo this, mt t800 had a pass air window? I cant seem to find a part number or anything for this can someone please help on this.
  2. Skate-Board
    Skate-Board Road Train Member
    Aug 9, 2014
    3,801
    Thanks Received:
    3,996
    Merrimack, NH
    If you can get yourself down to the Petro in El Paso, TX this guy is across the street. He is the absolute best and cheapest place to get it done for probably cheaper then you can do it yourself. He replaces windows, windshields and tinting. This whole street has lots of little places like truck detailing, truck fridge repair, tire regroving and lots of other stuff.
    Steinbrenner Thanks this.
  3. flc120
    Jul 11, 2012
    916
    Thanks Received:
    122
    I guess im stuck with leaving it manual, it would be great to at least get the part number for the factory air operated window
  4. flc120
    Jul 11, 2012
    916
    Thanks Received:
    122
    the dam manual regulator is $200 for thst id rather use that same money to.rig up an air window on truck, id probably be able to do both windows for that price. nonetheless only kenworth makes it no aftermarket companies make it so im stock with oem.
    this sucks not having a working pass window. im wondering if i can use a system of a peterbilt since its a pacar type door or see if i can make the freightliner one work.
  5. kwswan
    kwswan Road Train Member
    Jul 26, 2009
    1,939
    Thanks Received:
    10,257
    mcminnville,tn.
    Do you know what the vin# from the KW was? If so take it to the dealer & see if they can come up with some part numbers for it.
  6. bigguns
    bigguns Road Train Member
    Jun 13, 2013
    2,846
    Thanks Received:
    6,853
    Omega,GA
    I have a factory electric passenger window. '92 W9 #584764
  7. Harlow
    Harlow Bobtail Member
    Oct 14, 2015
    Thanks Received:
  8. Harlow
    Oct 14, 2015
    Thanks Received:
    Go to a truck salvage and find what you need. I switched mine from manual to electric. It was a pretty easy switch over.
