Warning About RUSH PETERBILT
Discussion in 'Peterbilt Forum' started by Azzitude, Oct 31, 2010.
  1. Azzitude
    Azzitude Bobtail Member
    Sep 26, 2010
    29
    Thanks Received:
    Conneaut, OH
    So I'm in Charlotte, NC and decide to get a PM done at RUSH Peterbilt, overpriced but what the hell .. I had time ....
    I tell them leave the fuel filters alone cause they were just changed at Cat a week ago, Rotella oil and add 2 gal of lucas ....and keep your balwin filter off my truck and use a Cat filter.
    So they drain the oil, drop the filter and spin a new Cat filter on, Add lucas first, then add the oil ..... start the truck and rev the motor for the oil pressure to get up and they shut it off and top off the oil ...
    now is sounds like the top end is not getting any oil .....clackety clack clack
    So i go back the same day and tell them something is not right and ask what did you do to my engine? ... they say nothing and hook the computer to it to check for codes .... low oil pressure codes ....2 of them ....from when they had it .... I check the oil and its a gallon low ... So I add oil only to find out they also broke the oil cap ... Now I tell them to walk me through what they did ...After they drained the oil.
    1. put on a new Cat Filter ....WITH NO FRIGGIN OIL IN IT!!!!
    2. Add Lucas .... BEFORE THE OIL
    3. add oil ... ON TOP OF THE LUCAS.
    Then they started it and could not get the oil pressure up so They Revved the motor for like 20 seconds till it came up .... :biggrin_25513:
    after 2k miles I had an oil sample taken and copper and iron are already high.
    I called RUSH Corporate and asked what they intended to do about it and they said they will not fix it.
    when asked why they did not prefill the oil filter they replied
    " we do not prefill the filter becuase that oil could be contaminated and would not get filtered before it hit the engine "
    So I asked them why they were putting contaminated oil in my truck. how they expected the lucas ( motor honey) to get sucked up through the pickup screen and fill the filter before any damage occurs?
    no reply ...
    Now when I start the truck cold the oil pressure comes to 50 and hovers for a minute then climbs to 65 slowly, the oil temp never gets higher than 150 and the truck runs cold all the time .... the longer it runs, the colder it gets till the oil temp does not even register on the gauge
    I am going to have to replace the main and rod bearings for scarring because they have no clue!!! and who knows what else can be wrong now ...have to goto cat and have them look at it i guess
    STAY AWAY FROM RUSH TRUCK CENTERS
  2. Les2
    Les2 Road Train Member
    Jul 25, 2008
    5,150
    Thanks Received:
    2,288
    kicked back in my lazyboy...
    Why 2 gallons of lucas?
  3. Azzitude
    Sep 26, 2010
    29
    Thanks Received:
    Conneaut, OH
    760,000 miles and it likes lucas
  4. Les2
    Jul 25, 2008
    5,150
    Thanks Received:
    2,288
    2 gallons is overkill but hey its your money and motor. I quit using it way back when it got to be over $20.00 a gallon. I also heard that lucas will mess up an oil sample reading?
    I'd like to know how long they ran it before it got oil pressure? If this is an electric motor you'd figure it would've shut down before any damage?
  5. ironpony
    ironpony Road Train Member
    Sep 23, 2007
    17,502
    Thanks Received:
    12,015
    Ask my GPS...
    I heard that Lucas basically increases the viscosity of the oil - makes it harder to pump. Good for extending the life of an engine that's having problems with fuel dilution. On an oil sample there may be some additional additive components (couldn't say precisely what you'd see - not an "expert",) but the viscosity number will be higher than it would without it.
  6. canuck in da truck
    canuck in da truck Road Train Member
    Aug 6, 2010
    4,352
    Thanks Received:
    2,601
    western pa
    wouldnt if anything the oil temp be high with additional wear?
    i am not sure that anything they did would be all that bad--true you really should fill filters first---and if your bearings were bad you should have lower oil pressure
    but then again i wasnt there and it isnt my engine---good luck and i hope everything works out for you
  7. Krooser
    Krooser Road Train Member
    Jul 25, 2010
    2,493
    Thanks Received:
    1,066
    Wisconsin
    A dry filter is no problem since the filter is on the backside of the oil pump... the pump will not suck air into the oil system on a CAT.
    canuck in da truck Thanks this.
  8. Azzitude
    Sep 26, 2010
    29
    Thanks Received:
    Conneaut, OH
    I took it to Hunter Peterbilt in Erie, PA yesterday and they pulled the oil filter .... Totally clogged up with what we think is the lucas, after it was replaced the truck again runs great ... now to get another oil analysis done on next PM to see what if any damage was done.
  9. truckbiz
    truckbiz Light Load Member
    Sep 22, 2010
    103
    Thanks Received:
    17
    North East corner of Illinois
    Sounds like you lucked out on this one! What happened with the water temp? I can't see where the two are related.
  10. canuck in da truck
    Aug 6, 2010
    4,352
    Thanks Received:
    2,601
    western pa
    even if the filter is plugged it shouldnt make it run better--it should just bypass
    but a very good point about the correct way to mix lucas and oil--
