What am I doing wrong
Discussion in 'Questions From New Drivers' started by Zacgehret, Jun 21, 2018.
  1. Zacgehret
    Zacgehret Light Load Member
    Jun 21, 2018
    67
    Thanks Received:
    54
    Kilbourne il
    Ok so when I shift in low gears when I first push the throttle the tuck jumps the guy who showed me how to drive said it was cuz I hit the throttle to hard six months later I'm still doing it I don't know how I can ease into it any slower without stalling it so could I be doing something else wrong and if not some advice on how to correct doing it wrong
  2. Odin's Rabid Dog
    Odin's Rabid Dog Heavy Load Member
    May 6, 2018
    704
    Thanks Received:
    1,717
    NW MT
    One thing you can try is wedge your throttle foot against the wall beside the pedal for support, can't do it on all trucks.
    Another thing that sometimes helps is move your foot further up on the pedal, if it's the pedal type that's long (rectangular). This makes so more travel distance is needed to add the same amount of throttle. Won't work if its a short (sort of square shaped) pedal.
    Bean Jr., Zacgehret and Maj. Jackhole Thank this.
  3. kemosabi49
    Jan 13, 2013
    10,686
    Thanks Received:
    45,871
    SW Arkansas
    What are the rpms when you shift up in low range?
  4. Zacgehret
    Jun 21, 2018
    67
    Thanks Received:
    54
    Kilbourne il
    Little under 15 in low range little higher if I'm loaded
  5. Zacgehret
    Jun 21, 2018
    67
    Thanks Received:
    54
    Kilbourne il
    Ill try moving my foot up the pedal more I do hit it pretty low
    Odin's Rabid Dog Thanks this.
  6. Maj. Jackhole
    Maj. Jackhole Heavy Load Member
    Mar 19, 2017
    807
    Thanks Received:
    4,202
    Definitely try further up on pedal. Have you also worked on your clutch release speed? To quick has same results if rpm's are right.
    KillingTime and Odin's Rabid Dog Thank this.
  7. Maj. Jackhole
    Mar 19, 2017
    807
    Thanks Received:
    4,202
    Your heel should be at the very base of the pedal using the back of the heel as your pivot point while placing pressure on the peddle, you will notice that the truck responds quicker and you have more control of the speed.
  8. QuietStorm
    QuietStorm Heavy Load Member
    Dec 11, 2016
    899
    Thanks Received:
    1,416
    I never throttle when shifting its unnecessary. Wait until after you're in the gear and rolling then ease onto it.
    stwik, okiedokie, DSK333 and 3 others Thank this.
  9. Brandt
    Brandt Road Train Member
    Sep 17, 2012
    4,519
    Thanks Received:
    6,193
    I can tell you how to shift and it will be so smoooth in low rang.
    The trick is shifting at 1,000 RPMs or less. The reason for this is because it's very hard to match the low rang gears. When you shift at 800-1,000 RPMs you don't even have to worry about the gear matching up. The truck can pull the trailer at this low RPM.
    Then when you going to high rang bring engine up 1600 RPMs
    Bean Jr., Lepton1 and kemosabi49 Thank this.
  10. KillingTime
    KillingTime Road Train Member
    Mar 26, 2016
    3,865
    Thanks Received:
    61,880
    Rockland, Maine
    This.
