What do I do if I want to hire an independent hauler?
Discussion in 'Ask An Owner Operator' started by etd66ss, Jun 3, 2019.
  1. etd66ss
    etd66ss Bobtail Member
    Jun 3, 2019
    4
    Thanks Received:
    5
    So, lets say I want to buy this thing: https://www.machinerytrader.com/lis...mantled-machines/25142609/1971-pettibone-88el
    It does not run, and not sure if the seller has a way to load it on the trailer. I think it weighs around 22,000 lbs. I'd need it moved from ZIP 28334 to 14094.
    First off, as an idependent hauler, would you take this job knowing it can't be simply driven onto the trailer?
    I'd de able to help unload it with my equipment.
    In a ballpark figure, how much would this haul cost?
    I have a bad feeling the shipping would cost more than the parts machine itself...
    Lepton1 Thanks this.
  2. Cat sdp
    Cat sdp . .
    Apr 8, 2012
    20,997
    Thanks Received:
    73,344
    Orion's Belt
    All loading/unloading time would be billed by the hour....
    And maybe you’d be billed for a rotator wrecker to help drag to on the trailer
  3. Spyro2112
    Spyro2112 Medium Load Member
    Mar 17, 2018
    604
    Thanks Received:
    416
    Will it fit on a flatbed tow truck,. Is it Bigger than a bread box
  4. Chinatown
    Chinatown Road Train Member
    Aug 28, 2011
    75,098
    Thanks Received:
    171,283
    Henderson, NV & Orient
    @Lepton1 may have some suggestions.
  5. Ridgeline
    22,418
    Thanks Received:
    116,685
    Yeah cat, we just did a tracked excavator and it was a big nightmare.
    The consignee who contacted a broker (who knew nothing about HE moving) was glad my driver knew what he was doing and we didn't charge by the hour but by the job. It worked out for them.
    I would recommend to the OP just getting a hold of someone through a company that does this a lot, like Landstar. AND yes the shipping will be more.
    NOW if you get it running (which it may be easy to do), a hotshot truck with a 35 foot trailer may work out for you and do it cheaply.
    Lepton1 and Chinatown Thank this.
  6. starmac
    starmac Road Train Member
    Apr 11, 2019
    6,639
    Thanks Received:
    12,528
    Fairbanks Ak
    No big deal, you should be able to contact anybody with a lowboy and get her done. If it is not too tall a landall would be even better, especially if there is not a piece of equipment there to push it up on a trailer.
  7. etd66ss
    Jun 3, 2019
    4
    Thanks Received:
    5
    I am guessing at the dimensions, but it is about 18' L X 8' W x 10' H
    I already have one, looking to get this one for a parts machine. I could get exact measurements from mine if it helps.
    Bottom line is, the machine is for sale for $2000, if the shipping is more than say $1200-$1500 I'd probably have to walk away from this one, just too far away.
  8. Midwest Trucker
    Aug 31, 2018
    5,903
    Thanks Received:
    21,335
    Your looking at atleast double that amount.
    Almost 700 miles.
  9. Lonesome
    Lonesome Mr. Sarcasm
    Dec 15, 2007
    11,202
    Thanks Received:
    23,020
    Northern Indiana
  10. etd66ss
    Jun 3, 2019
    4
    Thanks Received:
    5
    Ok, yeah, then that kind of settles it. Not worth the cost for a parts machine.
    Thanks.
    Lepton1, Midwest Trucker and Chinatown Thank this.
