What do you do to Protect your tarps from rips
Discussion in 'Flatbed Trucking Forum' started by Kshaw0960, Jan 17, 2019.
  1. Kshaw0960
    Kshaw0960 Road Train Member
    Jun 17, 2018
    1,581
    Thanks Received:
    5,023
    What do you folks use for protecting your tarps from rips? I don’t tarp a lot and do general freight so I need to be able to tarp a variety of things.
    I purchased that felt from tri city canvas and really like it. However it’s huge. The 12x15’ piece rolls up to something like 2.5ft squared. I have 3 of these rolls. Now ideally I would like to keep the 12x15’ size so I can cover a machine or be able to cover large sharp areas. The problem comes when trying to store and carry this stuff. It’s too large to fit anywhere.
    I’m thinking if I cut it into smaller squares I can store some in a side box, some in a step box, etc. What’s the best size to cut them into?
  2. Bakerman
    Bakerman Road Train Member
    Jan 27, 2013
    4,663
    Thanks Received:
    8,812
    Phoenix, AZ
    Buy yourself some carpet samples or some furniture moving blankets
    Nothereoften Thanks this.
  3. Nothereoften
    Nothereoften Light Load Member
    Oct 6, 2018
    261
    Thanks Received:
    265
    Keep old straps you don't mind cutting up to fit where you need. And carpet chunks
  4. HopeOverMope
    HopeOverMope Road Train Member
    Feb 25, 2016
    1,801
    Thanks Received:
    3,211
    I-20 LOUISIANA
    An old trick for crates is to tap the corners in with a hammer, I ask first. Then put a strap over the tarp by the edges if possible.
    Machinery is machinery. Your on the right track with the felt.
  5. Kshaw0960
    Jun 17, 2018
    1,581
    Thanks Received:
    5,023
    I started with around 14 moving blankets and within a few months they are all junk. The tape I use to hold them in place literally ripped them in half when I went to take the tape off.
    I bought a thin outdoor carpet and cut it in 1x1 squares and use a hammer style staple gun. It works ok but it still tears up.
    I guess I was looking for the optimum size to cut the felt.
    blairandgretchen Thanks this.
  6. Kshaw0960
    Jun 17, 2018
    1,581
    Thanks Received:
    5,023
    I’m thinking about cutting them 6x5ft. Can get 6 of them this size from the 12x15 felt pad.
  7. Tombstone69
    Tombstone69 Road Train Member
    Dec 20, 2018
    1,010
    Thanks Received:
    1,346
    Jersey shore
    Old rubber mudflaps can be cut into strips or any shape for that matter.Also good under straps on steel.Soft rubber ones are the best.
  8. REO6205
    REO6205 Road Train Member
    Feb 15, 2014
    13,168
    Thanks Received:
    60,490
    California.
    Check with your local fire department and see if they have any old 4" fire hose. A lot of times they'll have hose they'll give you for free just to get rid of it.
    Cut it into whatever lengths you need, slit it up one side, and you have a great tarp protector. The rubber inside is a good cushion and it stays on the load well. The canvas-like outside won't hurt your tarps.
    It's also good as a strap protector when you're not tarping but need something to keep from marking a load. In one foot lengths you can store more than you'll ever need in a small jockey box.
  9. Diesel Dave
    Jan 20, 2010
    9,235
    Thanks Received:
    29,484
    Hesperia, Ca.
    Times 2..... I have a few of those. Use them for softners on certain loads. No tarp loads for me.
  10. REO6205
    Feb 15, 2014
    13,168
    Thanks Received:
    60,490
    California.
    We still tarp lumber but other than that we don't do it anymore.
    We do haul quite a bit of new logging and farm machinery Some of the dealers scream bloody murder if you scuff the paint on a Cat or a grader so along with our rattle-cans of touch up paint we carry a box of the fire hose pads.
    D.Tibbitt, PoleCrusher and Diesel Dave Thank this.
