What is the SAFEST way to drive double clutch or floating
Discussion in 'Questions From New Drivers' started by Aarrons, Aug 7, 2017.
  1. Aarrons
    Aarrons Light Load Member
    Jul 13, 2015
    242
    Thanks Received:
    75
    Not the most efficient but the safest way of driving.
    I would like to send a message to the HR C that rejected my app because I didn't float flawlessly on my test drive.
  2. Zeviander
    Zeviander Road Train Member
    Jan 23, 2015
    4,887
    Thanks Received:
    36,995
    Winnipeg, MB, CA
    I'd say floating is both safer and more efficient. The less the driver is moving around in the cab, the more energy they can devote to driving the truck. Double clutching is just a waste of friction material.
    bigred81 Thanks this.
  3. Aarrons
    Jul 13, 2015
    242
    Thanks Received:
    75
    then why is it mandated by the dmv?
    CrappieJunkie Thanks this.
  4. ChaoSS
    ChaoSS Road Train Member
    Sep 20, 2014
    3,338
    Thanks Received:
    6,758
    Neither is safer. You should be able to double clutch, for safety reasons, some situations it is better to do it. Floating is more convenient, perhaps easier on the clutch, harder on the gears if your are less than perfect in your timing. Either way if a company wants you to be able to float and you can't, move on and find another company.
  5. MACK E-6
    48,986
    Thanks Received:
    227,295
    If you're on a downhill and the weight of the load begins to push against the driveline, you'll notice floating doesn't work very well anymore. At that point you'll at least need to push the clutch in to get it OUT of gear.
  6. Aarrons
    Jul 13, 2015
    242
    Thanks Received:
    75
    thanks I will use that on my reply to the c
  7. ChaoSS
    Sep 20, 2014
    3,338
    Thanks Received:
    6,758
    Again, I'd advise you just move on. No need to burn bridges, you never know what may happen in the future.
    ladr, sealevel and Big Don Thank this.
  8. haz-matguru
    haz-matguru Road Train Member
    Feb 18, 2012
    2,889
    Thanks Received:
    4,405
  9. I glide 47
    I glide 47 Road Train Member
    Jun 3, 2017
    1,426
    Thanks Received:
    1,523
    I float in low range double clutch in high side
  10. spyder7723
    spyder7723 Road Train Member
    Mar 31, 2013
    15,471
    Thanks Received:
    25,075
    sarasota, fl
    Mr safety will tell you the cdl book says to never ever shift going downhill. Or in an intersection. Or over a rail road crossing. Or while making a turn. Heck its got so many times of when not to shift its amazing we ever get out of the low side of the tranny.
    Double clutch, single clutch, float. None of them are any safer than any other.
    A21CAV, Lepton1, sealevel and 3 others Thank this.
