What rears are in this truck
Discussion in 'Peterbilt Forum' started by mailman66, Oct 2, 2018.
  1. mailman66
    mailman66 Bobtail Member
    Mar 23, 2016
    6
    Thanks Received:
    I'm trying to find repair manuals for my truck for future reference just in case its ever needed . The help that I'm asking for at this time is just what rears and Steer axles I have on this truck. I have included the data that I have from my build sheet
    This truck is a 2015 389 peterbilt and i can not read the data tag that is on the rears.
    the vin number is:1NPXDP9X8FD285424
    Front Axle : S/N MY01387504 { steer I think}
    FWD Rear: S/N :HN04610918
    MID Rear Axle: S/N: HN04610919
    If anyone knows of a web site where I can cross reference S/N numbers that would help, I have the build sheet on the truck but I can not find any thing on the rears.
  2. boneebone
    boneebone Road Train Member
    Mar 13, 2009
    2,297
    Thanks Received:
    2,371
    Unless it's missing, the manufacturer's GVWR sticker on the driver's side door jamb should have all that information.
    Oxbow Thanks this.
  3. mailman66
    Mar 23, 2016
    6
    Thanks Received:
    The manufacturers GVWR is unfortunately missing
  4. Goodysnap
    Goodysnap Road Train Member
    Jul 12, 2017
    3,745
    Thanks Received:
    9,105
    Steer Model Dana E14621
    Rears are Dana DSP40's
    magoo68, Oxbow and pushbroom Thank this.
  5. mailman66
    Mar 23, 2016
    6
    Thanks Received:
    Thanks for all your help!!!
    Oxbow and Goodysnap Thank this.
  6. spsauerland
    spsauerland Road Train Member
    May 31, 2010
    4,296
    Thanks Received:
    10,891
    West Harrison, In
    CHASSIS DETAIL FOR 285424 Print
    Model 389 Class 8
    Unit Type Tractor Stock Type Stock
    Invoice Date 10/31/2014 Build Date 10/2014
    VIN 1NPXDP9X8FD285424
    Sleeper Type "48"" LOW ROOF SLPR W/PLATINUM INTERIOR"
    Intended Service CAR CARRIER
    Commodity Hauled TRANSPORTATION EQUIPMENT
    GHG Door Label
    Design Element Value
    GHG Label Type COMPLIANTVOCTRUCK
    GHG Family Name FPCR2VOCV8TK
    GHG Regulatory SubCategory C8VOC
    GHG Model Year 2015
    VIN Number (as printed on GHG label) 1NPXDP9X8FD285424
    GHG Compliance Statement CS - COMP - US - EPA
    GHG Tire Component LRRA
    GHG Label Print Pass DateTime P2014 - 10 - 3022:01_002
    GHG Date Of Manufacture 2014 - 10 - 30
    DEALER TRUCK PURCHASE ORDER (DTPO) INFORMATION
    DTPO Order Date 6/24/2014 DTPO Number 60580048
    MAJOR COMPONENTS
    Type Make Model Serial #
    DIESEL PARTICULATE FILTER (DPF) - DEF TANK MEDIUM 56289145354
    ENGINE PACCAR MX - 13 Y064180
    FORWARD REAR AXLE DANA SPICER DSP40 HN04610918
    REAR REAR AXLE DANA SPICER DSP40 HN04610919
    STEERING AXLE DANA SPICER E1462I MY01387504
    TRANSMISSION FULLER RTLO18918B S1108951
    SAR, pushbroom and mailman66 Thank this.
  7. stillwurkin
    stillwurkin Road Train Member
    Dec 2, 2017
    1,756
    Thanks Received:
    2,856
    Metal on the rear end housings?
  8. spsauerland
    May 31, 2010
    4,296
    Thanks Received:
    10,891
    West Harrison, In
    Thickness? DS40 is 9MM, DS41 11 MM. 46K axles housings are usually 16MM.
    SAR Thanks this.
  9. mailman66
    Mar 23, 2016
    6
    Thanks Received:
    My is definitely DS 40 as it is 9mm
