What recording devices are installed in trucks?
Discussion in 'Questions From New Drivers' started by BAG, Sep 23, 2013.
  1. BAG
    BAG Bobtail Member
    Sep 22, 2013
    10
    Thanks Received:
    Moin,
    what recording devices are installed in trucks in America? As there are driving and rest times?
    Thanks in advance
    greeting
    123456 Thanks this.
  2. Ubu
    Ubu Road Train Member
    Aug 25, 2012
    1,252
    Thanks Received:
    1,178
    Rumored to be somewhere
    There are no required recording devices for trucks today but there is discussion and legislation in the works for mandating EBOR’s. Some (most) company’s already have EBOR’s and some even have cameras in the truck that look and both the road and the driver.
    As for the driving and rest times, See http://www.fmcsa.dot.gov/rules-regulations/truck/driver/hos/fmcsa-guide-to-hos.PDF for the hours of service regulations.
  3. chalupa
    chalupa Road Train Member
    Jul 22, 2010
    3,757
    Thanks Received:
    1,643
    Houston,Texas
    In the new ones ( not sure when on class 8 ) the ECM records the highest speed and highest RPM of the truck. Also records engine hours, miles and fuel gallons but no dates. The information can only be viewed at the dealer level and cannot be changed except by the factory on a re flash. It's viewable on my co pilot on my 98 Mack.
    This was in US cars years before and can be pulled in a fatality....and they do check it.
    The rest is on the dash and operated by the carrier.
  4. Pmracing
    Pmracing Road Train Member
    Jan 28, 2011
    6,354
    Thanks Received:
    3,178
    Arlington Heights, IL
    I drive a 2010 Volvo and the onboard data log shows the exact time a marker light failed!
    Mikeeee
  5. snowwy
    snowwy Road Train Member
    Jul 6, 2009
    20,570
    Thanks Received:
    13,294
    dayummmmmmmm
  6. Lepton1
    Lepton1 Road Train Member
    Nov 23, 2012
    12,647
    Thanks Received:
    25,589
    Yukon, OK
    It depends on what company you work for.
    With my company they record a lot of data, including speed, location, whether you have a significant braking event (defined by mph lost per second), overspeed incidents (defined by a fixed mph that you are never to exceed), potential rollover events (defined by lateral G force), mpg, idle time as a percentage of total engine time, etc. etc.
  7. SlowPoke44magnum
    SlowPoke44magnum Medium Load Member
    May 3, 2009
    407
    Thanks Received:
    519
    Walbridge,Ohio
    I just hired on to haul cryogenic liquids and we have EOBR's, Qualcom E-logs, VORAD and the Iteris lane deviation camera. I'm planning on running my own dash cam as well to cover my arse in case some idiot decides to do something stupid. The Iteris system records too but only within a limited field of vision and only if there's an "event", that's why I'm going to run the dash cam.
  8. BAG
    BAG Bobtail Member
    Sep 22, 2013
    10
    Thanks Received:
    thanks for the info
