What would you do? Routing help because of under powered truck.
Discussion in 'Questions From New Drivers' started by jme2788, Apr 14, 2021.
  1. jme2788
    jme2788 Bobtail Member
    Apr 12, 2020
    17
    Thanks Received:
    9
    My box truck is a little slow going up hills. I’m traveling to Boston and I’m wondering if I should take 76 east or 80 east through Pennsylvania.
    76 turns to 78 which goes through NYC. But if I take 80 I’ll be going across the Northern part of the state and I’m wondering if it will be more mountainous
    sorry if this post is a lot of rambling
    austinmike Thanks this.
  2. jme2788
    Apr 12, 2020
    17
    Thanks Received:
    9
    the state in question is Pennsylvania, if not already obvious
  3. Linte_Loco
    Linte_Loco Road Train Member
    Apr 24, 2011
    1,618
    Thanks Received:
    6,485
    LA (lower Alabama)
    Where are you starting?
  4. Moose1958
    Moose1958 Road Train Member
    Dec 17, 2010
    15,169
    Thanks Received:
    33,411
    Williesburg, Virignia
    I prefer the mountains over those tolls. I 80 unless there is a lot of snow is OK. Even with a box truck going from the Ohio line to Carlisle is going to be VERY expensive. My best guess is $80+.
  5. tallguy66
    tallguy66 Medium Load Member
    Oct 18, 2018
    534
    Thanks Received:
    873
    80 isn’t much worse then 76 in terms of hills
  6. Rideandrepair
    Aug 8, 2015
    17,342
    Thanks Received:
    56,259
    From Youngstown, really no way around 80, 78s just going to be longer, and cost a fortune. Shortest route, 80-81-84-90. Or 11 miles further 80-287-95-91-90, Or 24 miles further 80-287-95. I think the last route might be best, one toll going into White Plains NY. Best going through at night. Less hills after that. I definitely wouldn’t take the GW bridge. I’ve only taken the first route once, headed west, years ago. As I recall it had a lot of hills. Maybe someone else knows how much the tolls are, or knows a better route.
  7. slow.rider
    slow.rider Road Train Member
    Apr 4, 2017
    2,005
    Thanks Received:
    4,740
    NYC
    Not the least hilly but there's almost no tolls and the hills are mostly manageable. The least hilly of all would be 80-95 thru NYC and pay the tolls.
    80 thru PA is less hilly than 76. I mean, thru PA they're both 100% hilly, but the hills on 76 are taller. On 80 I can usually get to the top before needing to downshift. And as an added bonus, 76 is the most expensive tollway in the world, whereas 80 is free.
    Just my $0.02.
  8. Espressolane
    17,548
    Thanks Received:
    107,512
    Does not really matter what route you choose. If you are traveling at a slow speed, please stay in the right lane as much as possible. You will much more appreciated.
    Brettj3876 Thanks this.
  9. Brettj3876
    Brettj3876 Road Train Member
    Nov 18, 2014
    11,257
    Thanks Received:
    54,058
    Land of local
    That's prob how'd I'd go too. No getting round them hills. I've only ever been on 76 across pa once. The hills on 80 are a little less and you don't have all those skinny sections like on the pike
  10. Brettj3876
    Nov 18, 2014
    11,257
    Thanks Received:
    54,058
    Land of local
    Or you could always run the high road 86/90 across ny might be a better option. Where are you starting from?
    A lot flatter that way. Few small hills in western NY
    TokyoJoe, Doealex and slow pok Thank this.
