where are the battery terminals
Discussion in 'Questions From New Drivers' started by Lspilot82, Aug 30, 2012.
  1. Lspilot82
    Lspilot82 Light Load Member
    Aug 8, 2010
    226
    Thanks Received:
    88
    Im trying to jump my car off with my truck but seems i can't find the terminals to do so. Is a 2012 t660....where are they located
  2. Cranky Yankee
    Cranky Yankee Cranky old ######
    Jan 31, 2012
    15,317
    Thanks Received:
    209
    Green Bay Wi
    the 2010 has batteries drivers side behind the cab steps
    many have jumper pole right behind the cab just a red and blk lug
  3. Lspilot82
    Aug 8, 2010
    226
    Thanks Received:
    88
    I cant find anything that looks like what your talking about
  4. Cranky Yankee
    Jan 31, 2012
    15,317
    Thanks Received:
    209
    Green Bay Wi
    well behind the step up into the cab should be a flat plastic piece where the batteries are wingnuts to remove that cover maybe
  5. PackRatTDI
    PackRatTDI Licensed to Ill
    Jul 15, 2006
    14,765
    Thanks Received:
    22,567
    El Chuco, Tejas
    My Freightliner has a positive jump lug under the hood. Maybe it's there.
  6. Milktanker
    Milktanker Medium Load Member
    Jun 25, 2012
    373
    Thanks Received:
    252
    Frenchtown, mt
    To get to the battery's you have to undo the four bolts on the drivers side fairing 5/8 I believe. Or there is a jump post on the frame rail under the hood on most 660s I've worked on
  7. Lspilot82
    Aug 8, 2010
    226
    Thanks Received:
    88
    im going to go look again
  8. Worthken
    Worthken Light Load Member
    Jun 2, 2012
    265
    Thanks Received:
    83
    Delmas South Africa
    Just trace the red cable from the starter, you will eventually find the batteries.
    NavigatorWife Thanks this.
  9. Pmracing
    Pmracing Road Train Member
    Jan 28, 2011
    6,354
    Thanks Received:
    3,178
    Arlington Heights, IL
    If you can't find the terminals, you probably should not be attempting the procedure.
    Sorry to say.
    Mikeeee
  10. BigJim1937
    BigJim1937 Medium Load Member
    Mar 27, 2012
    303
    Thanks Received:
    135
    Fargo,ND
    Try asking someone with another car for a boost
