Where can I find a Yagi mount?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by LimpyLegs, Sep 22, 2019.
  1. LimpyLegs
    LimpyLegs Medium Load Member
    Aug 26, 2008
    342
    Thanks Received:
    172
    Midland,VA
    Does anybody manufacture antenna pole mounts for a Yagi antenna to attach to the mirror?
    I'm trying to get some better LTE reception.
  2. Ridgeline
    22,420
    Thanks Received:
    116,709
    are you stationary or on the move?
  3. LimpyLegs
    Aug 26, 2008
    342
    Thanks Received:
    172
    Midland,VA
    I will be stationary when I use the antenna. I need to detach the antenna for when I'm moving
  4. Ridgeline
    22,420
    Thanks Received:
    116,709
    Ok the antenna weighs what?
    Under 5 lbs?
    try a cb mirror base stud mount and some aluminum tubing. I can envision it but describing it is ... hard with these idiots around me.
    LimpyLegs and homeskillet Thank this.
