where can I get a job if I have an older truck
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by mca1895, Dec 5, 2017.
  1. mca1895
    mca1895 Bobtail Member
    Dec 5, 2017
    4
    Thanks Received:
    Everyone says I need to lease their truck.. that is BS., I am in Ohio btw
  2. Lonesome
    Lonesome Mr. Sarcasm
    Dec 15, 2007
    11,160
    Thanks Received:
    22,892
    Northern Indiana
  3. Chinatown
    Chinatown Road Train Member
    Aug 28, 2011
    74,824
    Thanks Received:
    170,524
    Henderson, NV & Orient
    Triple Crown Services
    Tractor Specification...
    TCS may aid you in the process of obtaining a tractor if you do not currently own one. TCS will assume no financial responsibility for your tractor payments or your qualification for a tractor loan.
    If you own your own tractor or plan to provide one from an outside source, it must meet the following specifications:
    • Tandem axle
    • TCS prefers that the tractor weigh 18,500 lbs. or less
    • Tractors must be equipped with a 24-inch sliding fifth wheel, mounted to slide 12 inches ahead of and 12 inches to the rear of center. Our fifth wheel mounting requirements are 47" maximum from the ground
    • Must be in good mechanical and cosmetic condition and must pass a current DOT inspection at an authorized TCS location. DOT inspections must be done every 6 months
    Note: Because of the weight and height of our 53 ft. trailers, the above requirements are very important. Please contact your TCS representative with any exceptions to the above specifications.
    TCS has terminal locations in the following cities:
    • Detroit, MI
    • Kansas City, MO
    • Harrisburg, PA
    • Greer, SC
    • Atlanta, GA
    Don't live within 50 miles of one of the above terminals? Don't want to be home every night? We still have opportunities for you!
    Call us for the details...
    [​IMG][​IMG]
