Where can you find the DOT forms online?
Discussion in 'Questions From New Drivers' started by Ryum, Feb 2, 2011.
  1. Ryum
    Ryum Bobtail Member
    Nov 5, 2010
    35
    Thanks Received:
    I need the physical card, and long form paperwork. I am looking through the texas DMV site, and fmcsa.dot.gov to see if I can find it. They are not exactly user friendly so wanted to check and see if anyone here happened to know where I could get them.
    edit: is this is?
    http://www.fmcsa.dot.gov/documents/safetyprograms/Medical-Report.pdf
    and that's all you take to get the exam?
  2. frontrange
    frontrange Light Load Member
    Nov 18, 2010
    78
    Thanks Received:
    190
    Northern Michigan
    Any clinic that does DOT physicals will have the forms and the card, and will furnish them.
  3. Rerun8963
    Rerun8963 Road Train Member
    Mar 30, 2006
    3,917
    Thanks Received:
    2,012
    ova-hereee
    just so that you know, a paper DOT card is not acceptable...it has to be the cardboard type given by the clinic/doctor/trunking company....now i should back this up a bit and say, "here in my area, and the states i deal with, a paper DOT health card is unacceptable."...maybe texas allows this, but to be on the safe side, go to the clinic....or even look for the local ATA affiliate trucking chapter in your state, as they will have just about ANYTHING a driver needs....
  4. Ryum
    Ryum Bobtail Member
    Nov 5, 2010
    35
    Thanks Received:
    Actually the CVS I am heading to does not have the form otherwise I wouldn't have asked
  5. 123456
    123456 Road Train Member
    Oct 22, 2010
    10,555
    Thanks Received:
    5,746
    32179
    A photocopy, on paper is all I've ever used,
    no problem in the lower 48 !!
  6. 123456
    Oct 22, 2010
    10,555
    Thanks Received:
    5,746
    32179
  7. Rerun8963
    Mar 30, 2006
    3,917
    Thanks Received:
    2,012
    ova-hereee
    by your link, thank you for confirming what i had said...
    Print the Certificate on cardstock paper. It is permissible to reduce the size of the Certificate.
    http://www.wisegeek.com/what-is-cardstock.htm
    The name cardstock comes from "card stock," which originally meant the stock of card as received from the manufacturer. Today, cardstock, for which cover stock is sometimes used as a synonym, is used for a range of paper weights that are in demand for scrapbooking, as mounting surfaces for prints to be framed, for making business cards and greeting cards, and for a variety of paper crafts. The main features that distinguish a sheet of cardstock are weight, fiber, color, finish and surface texture, and size. Of these, weight is the feature that actually defines cardstock.
    in other words, even by the DOT, ordinary paper is not allowed.....
  8. 123456
    Oct 22, 2010
    10,555
    Thanks Received:
    5,746
    32179
    Read the sentence above that................sheeesh
  9. CondoCruiser
    CondoCruiser The Legend
    Apr 18, 2010
    19,726
    Thanks Received:
    18,734
    Tennessee
    You can print on photo paper or cardstock like rerun says.
    It shouldn't be an issue like frontrange says, the doc supplies them.
    You get good at it, then you can start printing money, lol.
  10. Rerun8963
    Mar 30, 2006
    3,917
    Thanks Received:
    2,012
    ova-hereee
    "$20" get's you what...??? 10....15...at "Club Fed"...???
