Which option should I choose
Discussion in 'Ask An Owner Operator' started by Loyal1994memphis, Feb 27, 2019.
  1. Loyal1994memphis
    Loyal1994memphis Bobtail Member
    Feb 27, 2019
    Thanks Received:
    2012 volvo with cummings egine 455k miles or 2014 volvo D13 610k miles both are same price
  2. Gdog66223
    Gdog66223 Road Train Member
    Dec 30, 2017
    1,871
    Thanks Received:
    2,569
    Coal Town
    Do you know if the DPF filters have been cleaned or replaced on either truck...
    Eddiec and Loyal1994memphis Thank this.
  3. kemosabi49
    Jan 13, 2013
    10,706
    Thanks Received:
    46,014
    SW Arkansas
    Have ans oil analysis done on engine oil, tranny and rears, have dyno run with blow by test and get an ECM dump. Then get a trustworthy mechanic to check it out. Go from there. Anything less you might as well flip a coin.
  4. snowwy
    snowwy Road Train Member
    Jul 6, 2009
    20,564
    Thanks Received:
    13,288
    Take the least mileage truck for the same price. Also easier to get worked on with cummins over volvo engines. Rest of the truck will be bad enough as it is to get worked on.
    Loyal1994memphis and Bean Jr. Thank this.
  5. Army91W
    Army91W Heavy Load Member
    Nov 3, 2006
    751
    Thanks Received:
    733
    San Antonio, TX
    Volvo engines have injector cup issues. Cummins you’re looking at a dpf and doc if they haven’t already been replaced.
    It’s a roll of the dice no matter what. Have money for maintenance.
    Loyal1994memphis Thanks this.
  6. GreenPete359
    GreenPete359 Road Train Member
    Oct 21, 2017
    2,152
    Thanks Received:
    5,101
    Driving my recliner
    As a driver, i’d prefer the ‘14 with the d13. Anything 2012 would scare the heck out of me.
    As purchaser, Neither one!!! Again 2012 to me is no no. A Volvo that is 1/2way thru it’s life is a no go.
    Make sure you get some maintenance records, oil samples, solid inspections & go from there. Listen to the folks you’re paying...You’re paying them for their professional opinions listen to ‘em.
  7. Midwest Trucker
    Aug 31, 2018
    5,907
    Thanks Received:
    21,364
    What are you looking to spend? I’m not a big fan of either option. I do run Cummins engines though if that tells you anything.
