Who do counterbore cutting on isx engine in Georgia
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dcl, Aug 18, 2016.
  1. Dcl
    Dcl Bobtail Member
    Aug 18, 2016
    8
    Thanks Received:
    Counterbore cutting on isx in Georgia
  2. Snailexpress
    Apr 28, 2014
    2,675
    Thanks Received:
    6,068
    Rocky
    Haggai Diesel
    greenbee Thanks this.
  3. Ridgeline
    22,386
    Thanks Received:
    116,280
    Just curious, why is this in the new drivers question part of the forum?
  4. baha
    baha Road Train Member
    Jul 25, 2013
    4,137
    Thanks Received:
    2,836
    ga
    If its a bad there is a truck mounted line bore an liner counter bore machine man that works out of atl. ga. he will work on it at their shop or will drive out to the shop to counterbore wore/out blocks
  5. Dcl
    Dcl Bobtail Member
    Aug 18, 2016
    8
    Thanks Received:
    Should you happen to have the name or the number to the shop
  6. Dcl
    Dcl Bobtail Member
    Aug 18, 2016
    8
    Thanks Received:
    Would you happen to have a name or a number for the shop in atl
  7. Dcl
    Dcl Bobtail Member
    Aug 18, 2016
    8
    Thanks Received:
    If is not a problem would you happen to have a name or number to the shop in Atlanta
  8. baha
    Jul 25, 2013
    4,137
    Thanks Received:
    2,836
    ga
    Will send num. to you in morn. when I get it.
  9. Moosetek13
    Moosetek13 Road Train Member
    Nov 1, 2010
    14,671
    Thanks Received:
    18,438
    Burnsville, MN
    What is counterbore cutting?
  10. baha
    Jul 25, 2013
    4,137
    Thanks Received:
    2,836
    ga
    Helps to make liner stick up enough after its crap out the bottom of block and head gasket keep blowing he cuts block then shims liner up to make block like it was before liner started moving up and down
