who does the background check?will a mismeanor show up?
Discussion in 'Questions From New Drivers' started by mcwill, Oct 8, 2010.
  1. mcwill
    mcwill Bobtail Member
    Oct 8, 2010
    Thanks Received:
    cumming,ga
    back in april in another state,not the one i'm from.asked to search the vehicle.little did i know,an ex girl friend had hid a very small amount of meth in my laptop case.if i had know,i wouldnt have give the ok to search.they found it,was charge,fined,went to court,charge dropped to a mismeanor,if i plead guilty.did,payed the fine,had to do 40 aa meetings,no report to probation,just paid 40 a month till the aa is done,and im off,and mismeanor is surpose to be off my record.will dot or who ever does the background check fine it,been hired by a company,for training.start in 2 weeks.if i can get the rest of aa over.should i go on,or just forget it,and look for work else where?thanks.
  2. Smurfette
    Smurfette Light Load Member
    Aug 5, 2010
    278
    Thanks Received:
    71
    Phoenix, AZ
    Most of the time if you just tell them what happened they may be lenient but if you flat our lie you could cut your own throat.
  3. Rerun8963
    Rerun8963 Road Train Member
    Mar 30, 2006
    3,917
    Thanks Received:
    2,012
    ova-hereee
    you have some time from now till you graduate. what you NEED to do is find out if this really was removed off your record. till then, KEEP QUIET.....
    now if it is not removed, contact your lawyer. when you fill out applications, then you will have to note this. find out for sure what the misdemeanor charge will be. but typically, a misdemeanor should NOT be as big a problem as a felony.....
    jerryy123 Thanks this.
  4. RESPECT
    RESPECT Light Load Member
    Sep 24, 2010
    66
    Thanks Received:
    5
    Jasper, AlaFreakinBama
    sry i reread ur post i have nothing to say
