Who has the best mpg ?? Specs please!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Fullforce, Feb 8, 2012.
  1. Fullforce
    Fullforce Light Load Member
    Feb 2, 2012
    87
    Thanks Received:
    6
    Henderson tn
    Fixing to buy a truck in a few months and have to many setup options to look at. I'm personally looking fror a pre2002 truck as my budget is about 25 to 30k.
    Anyways I don't care about the looks of the truck I just need a sleeper with double bunk and the best fuel mileage I can possibly get!
    I can drive 55mph all week if I need to.
    So what are you driving? Engine specs, tranny, rear gear ratio, tire size, what trailer are you pulling, how many miles on truck, and what speed do you run?Ect ect
    Thanks !
  2. JDP
    JDP Medium Load Member
    Sep 25, 2011
    377
    Thanks Received:
    404
    Dubuque, IA
    It would probably help to describe the type of cargo you haul, typical weight, terrain you run across, and all those variables that go into speccing a truck.
  3. Fullforce
    Feb 2, 2012
    87
    Thanks Received:
    6
    Henderson tn
    I'll be hauling Flatbed and refeer more than likely always at 75 to 78k and driving everywhere.
  4. shovel82
    shovel82 Bobtail Member
    Feb 5, 2012
    17
    Thanks Received:
    mn
    It's not what i got but a t600 kw with 12.7 det 13spd and 3.55 rears sounds what u looking for that combo would knock down easy 6 mpg setup or a 6nz cat but the cat will cost more in getting then a detroit powered truck will cost. Could do freightliner but wiring harder to work on and cabs are noisy. Just my 2 cents and what I've seen.
    Fullforce Thanks this.
  5. SpankingGT
    SpankingGT Light Load Member
    Sep 9, 2010
    253
    Thanks Received:
    55
    14l-det series 60- 475-13speed eaton-2.93 rear- Firestone m726el drives- Michelin steers- 105-110 all around. Usually around 74-76k- route CA-NJ- average around 6.4 ish... Factor in heavy winds and it starts to drop dramatically.
  6. JohnP3
    JohnP3 Road Train Member
    Feb 21, 2010
    1,594
    Thanks Received:
    683
    Rock Creek B.C. Canada
    Every engine has an EPA sticker that tells you how many MM3 of fuel it takes to make the advertised HP.
    Freightliner wiring, you peal back the covering and look at the number, look in the book, it tells you the exact length of wire where it comes from and were it goes to, and what size it is.
  7. kajidono
    kajidono Road Train Member
    Jun 1, 2009
    6,422
    Thanks Received:
    4,659
    Streetrat
    Just looked at an 06 classic today. Nice truck with a 515hp 14L detroit. Had that problem with the turbo huffing and cutting out though, and some idiot decided that the jake needed to be on a separate switch on the floor like the old style high beam button. Only wanted $28k but no thanks.
    This old oil spewing thing is back to getting close to or over 7mpg with an N14, 13sp, and 22.5 tires. Not sure what the rear end ratios are.
    I agree, 6mpg is easy with a t600. Last t600's I drove were full height with 475 cat c-15's and auto 10's. Mine got 5.9 at the worst, 7.1 pulling new wabash trailers with the skirts. Also had 22.5 super singles. That was at 65. One of them was limited to 72 and averaged 7.3. That was with the engines turned down by some idiot in the office.
    The t600 I drove for Arrow was a mid roof, 425 cat, 10 speed, limited to 70. That one averaged 7.5 or better the whole time I drove it.
  8. SHC
    SHC Spoiled Rotten Brat O/O
    Feb 26, 2011
    8,484
    Thanks Received:
    7,046
    Westville, IN
    My 1999 FLD120 had 12.7 Detroit, 10spd and 3.90 rears. At 60mph i would avg 7.5mpg pulling a van trailer and this was with a flat-top truck dragging 5' of trailer in the wind. When i switched to dry bulk I went to 8mpg avg. Should have never sold the dang truck :(
  9. kajidono
    Jun 1, 2009
    6,422
    Thanks Received:
    4,659
    Streetrat
    ####, just think what it would have done with that bully dog kit on it.
  10. Sako3006
    Sako3006 Bobtail Member
    Oct 3, 2011
    48
    Thanks Received:
    13
    Southeast
    I think the thing to keep in mind is that you want an aero truck no matter what manufacturer you go with. Engine rating would be somewhere around 400-450hp with a 13 speed. Rear end in the low 3's should maximize that hp and keep the engine in a good rpm range. Tire size is 22.5's and road speed around 58 to 62mph. Just my opinion, but this setup should be good for 75k lbs while maximizing fuel economy. Also, a midroof may be your best bet for versatility.
