Whole trailer flashes with hazards on
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Kurt schaneman, Sep 22, 2015.
  1. Kurt schaneman
    Kurt schaneman Bobtail Member
    Aug 28, 2015
    19
    Thanks Received:
    4
    I've been getting all of our trailers ready for harvest and have one that's giving me fits...when I have the running lights on and the hazards the whole trailer flashes...if I turn the running lights off everything works as normal...and it doesn't do it when one or the other turn signal is used...only with running lights on and hazards on...also its only on the trailer I've been using the same truck for 3 other trailers and don't have this problem...any help would be great thanks
  2. lester
    Jan 2, 2012
    2,930
    Thanks Received:
    7,925
    NW, Iowa
    Grounding issue
  3. AModelCat
    29,390
    Thanks Received:
    161,299
    2nd that^^^
    Electricity is like most of us (lazy). It will always take the easiest path to ground.
  4. Kurt schaneman
    Aug 28, 2015
    19
    Thanks Received:
    4
    So where do I start? Should I just try and re ground the plug?
  5. AModelCat
    29,390
    Thanks Received:
    161,299
    Best approach to electrical is to work systematically. Personally, I'd start at the tail lights. The wires back there tend to rot out over time due to water and road salt. The plug could be an issue as well.
    T_Bone Thanks this.
  6. baha
    baha Road Train Member
    Jul 25, 2013
    4,137
    Thanks Received:
    2,837
    ga
    Does it do it with every truck thats hooked to trailer, a extra ground wire from frame to side of 5th wheel plate is the only way to fix some trucks?
  7. lester
    Jan 2, 2012
    2,930
    Thanks Received:
    7,925
    NW, Iowa
    I'd start with tail lights, checks the wiring like the other guy said. Our 6 or 7 year old Wilson had so much dirt and sand behind the tail lights it was crazy ( I do lots of gravel and don't slow down much.) Anyway wire back there shorted and wad causing me issues. Didn't find it until that tail light melted
  8. nikmirbre
    nikmirbre Road Train Member
    Jul 27, 2011
    5,539
    Thanks Received:
    10,161
    High Point NC
    I had same exact issue when trying to rewire the rear of my trailer......I had 2 lines crossed.......
  9. DoubleO7
    DoubleO7 Road Train Member
    Aug 21, 2015
    1,532
    Thanks Received:
    1,598
    Southern Illinois
    There you go!
  10. lots of character
    lots of character Road Train Member
    Aug 12, 2015
    1,031
    Thanks Received:
    1,814
    I hate trailer wiring..
    I really hate harvest trailer wiring. With a passion. Corn and hay rotting in the interstate bumper with mud. FML buddy.
    Test light. Start at the back. $64 says its a corroded scotch long or butt connector
    KPS Thanks this.
