Why are there no scales on most of the turnpikes?
Discussion in 'Questions From New Drivers' started by prosidius, Aug 9, 2018.
  1. prosidius
    prosidius Light Load Member
    Jul 15, 2016
    252
    Thanks Received:
    239
    Wisconsin
    I don't think I 90 in NY has a scale, Ohio and Indiana don't on there toll roads, and the Penna Turnpike is free of scales also. What's stopping a guy running from NY to Illinois really overweight knowing they won't see a scale?
    andhe78 Thanks this.
  2. buddyd157
    buddyd157 Road Train Member
    May 25, 2017
    13,582
    Thanks Received:
    34,896
    under a shade tree
    don't they have rolling scales at the toll plazas? or road sensors in the lanes as you drive?
    their gonna gitcha....i'm telling on you...
    rabbiporkchop Thanks this.
  3. Manny328
    Manny328 Light Load Member
    Jul 6, 2018
    71
    Thanks Received:
    58
    I've noticed this too
    NY sets up at rest areas
    So
    I'm guessing the travel plazas are part of there weigh station bs
    I've also noticed that alot of the toll roads you mentioned are tore up and pot hole ridden
    Probably from people knowing they are less likely to be weighed
    Only place I've ever noticed trucks hauling triples too
    slow.rider Thanks this.
  4. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,017
    Thanks Received:
    42,140
    White County, Arkansas
    Triples are special. They are regulated where they can go and what can be done with them I don't stress about those.
    If you had to build scale houses and then go through all of the stuff with herds of trucks it would add costs. I never see a scale on toll roads. However that does not mean there are ways to weigh trucks at the toll gate if they wanted to.
    I don't have a problem with that. As far as running toll roads as a overweight, that's not something I ever did. With the exception of containers, however there was a permit weight on those at around 100K give or take. (Richmond toll route, I-95 back in the day) Or the Baltimore tunnel system.
    If you know that you are overweight at the shipper or first available CAT scale, you will get that problem fixed before you proceed any further. If you did not, then you are not the Trucker you need to be.
  5. Numbnuts69
    Numbnuts69 Light Load Member
    May 25, 2018
    88
    Thanks Received:
    114
    Indiana has a CAT scale at the 1st eastbound service plaza and last westbound service plaza if that's what you mean.
  6. brian991219
    brian991219 Road Train Member
    Aug 10, 2013
    2,999
    Thanks Received:
    6,091
    Lords Valley, PA
    Some of the roads you mention use portable scales set up randomly at rest areas and entrance ramps. NY is well known for this. Others like the PA Turnpike weigh you as you get on going thru the tool booth and your toll covers excess weight to a certain degree. A few other toll roads are private, or have exceptions from traditional weight limits since they are not Federally funded.
  7. JonJon78
    JonJon78 Road Train Member
    Jul 1, 2018
    7,207
    Thanks Received:
    42,193
    Scales are for generating money. They are making it off you by the huge amount they charge to run the toll road.
    special-k Thanks this.
  8. windsmith
    windsmith Road Train Member
    Sep 2, 2011
    7,296
    Thanks Received:
    6,032
    NEPA
    Sorry to burst your bubble, but the PA turnpike has a scale in every toll lane. That's right, you get weighed when you roll through.
    brian991219 and rabbiporkchop Thank this.
  9. kemosabi49
    Jan 13, 2013
    10,901
    Thanks Received:
    47,292
    SW Arkansas
    I thought Ohio does too.
  10. windsmith
    Sep 2, 2011
    7,296
    Thanks Received:
    6,032
    NEPA
    Maybe, but I can only speak for the PATP.
