Would a smaller inverter last longer?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Stone Dude, Jan 8, 2017.
  1. Stone Dude
    Stone Dude Light Load Member
    Sep 20, 2016
    120
    Thanks Received:
    118
    Iowa
    My company truck came with a 2000 watt inverter, which is pretty nice. But really all I use it for is for my 27" monitor and my PS4 Slim which from my googling use 45 and 40-65 watts (depending on what it's doing) respectively.
    I know the bigger the inverter the more power it uses, so I'm wondering if I get a smaller inverter (120-150 watt should work, right?) would it run the pair for longer before the battery warning goes off? Or would the difference by negligible?
    I get a bonus for idling the truck under a certain amount, so I'm trying to get that as low as possible, but if we're talking about gaining a few minutes of juice then it's probably not worth it.
    Anyway, just an idea. If anyone could shed some light on the subject that would be great.
  2. MidWest_MacDaddy
    Feb 21, 2015
    11,172
    Thanks Received:
    18,801
    South Carolina
    Interesting question...
    my gut says "probably not worth it"
    Yes a larger inverter "can" use more power simply because it can handle more watts but I don't know if you are only running 100 watts through it if there would be more overhead on the total consumption or not ...
    Anyone here with a degree in EE might have some insight. Or just get one and play until the batteries are dead... and then compare... LOL
  3. tscottme
    tscottme Road Train Member
    Jul 25, 2008
    14,277
    Thanks Received:
    27,447
    Somewhere out West, in my mind.
    You big inverter will only pull from the batteries the power it consumes. If your uses pull 120 watts, that's all it pulls from the batteries, no matter how much more it could pull. Think of it as dipping your coffee cup into a small pan of water or dipping it into a swimming pool. Either way, you are only pulling a coffee cup amount of water out of the "water supply" or battery.
    snowwy and rzl-dzl Thank this.
  4. Gunner75
    Gunner75 Road Train Member
    Mar 17, 2014
    5,701
    Thanks Received:
    9,074
    Jackson Center Ohio
    You want an inverter that can handle double what your normal use is. Mainly for those times where you might peak out on your draw. So if all your normal usage is 150 watts, you want at a minimum of 300. And from what I recall a ps4 uses a lot more than 45 watts.
  5. dngrous_dime
    dngrous_dime Road Train Member
    Jan 28, 2014
    3,150
    Thanks Received:
    5,765
    Lansing area, MI
    @TROOPER to TRUCKER would probably know...
  6. TROOPER to TRUCKER
    TROOPER to TRUCKER Anything Is Possible
    Dec 15, 2014
    7,668
    Thanks Received:
    12,716
    Charlotte, NC
    Actually I had a APU so can't help much here
  7. dngrous_dime
    Jan 28, 2014
    3,150
    Thanks Received:
    5,765
    Lansing area, MI
    I meant regarding the PS4 power usage.
  8. TROOPER to TRUCKER
    Dec 15, 2014
    7,668
    Thanks Received:
    12,716
    Charlotte, NC
    I run a Xbox one lol
    flatbeb mac Thanks this.
  9. TROOPER to TRUCKER
    Dec 15, 2014
    7,668
    Thanks Received:
    12,716
    Charlotte, NC
    It is really a pc so should be about the same
  10. dngrous_dime
    Jan 28, 2014
    3,150
    Thanks Received:
    5,765
    Lansing area, MI
    Well, I tried. I used to know the answer, but it's been years since I did any solar power calculations..
    TROOPER to TRUCKER Thanks this.
