Would you run with this weight like this?
Discussion in 'Questions From New Drivers' started by prosidius, Nov 1, 2017.
  1. prosidius
    prosidius Light Load Member
    Jul 15, 2016
    252
    Thanks Received:
    239
    Wisconsin
    Going from western Michigan to Nashville. Tandems already in 12th hole.
  2. okiedokie
    okiedokie Road Train Member
    Jun 13, 2011
    12,203
    Thanks Received:
    90,730
    PNWET
    Slide your 5th wheel forward.
  3. STexan
    STexan Road Train Member
    Oct 3, 2011
    14,963
    Thanks Received:
    29,154
    Longview, TX
    Huh?
    Slide your trailer tandems toward the trailer doors and make it right and roll. What does the "12th hole" have to do with anything since you're not going to California?
    2 or 3 holes, either one, should probably work fine.
    mslashbar, Toomanybikes, ladr and 2 others Thank this.
  4. sherlock510
    sherlock510 Road Train Member
    Jul 26, 2011
    1,066
    Thanks Received:
    1,058
    Intercontinental.
    Can you afford an overweight ticket is real question here...
    and yes, i probably would.
    CrappieJunkie and G13Tomcat Thank this.
  5. albert l
    albert l Road Train Member
    Feb 10, 2013
    1,040
    Thanks Received:
    1,505
    On the Road
    Tell your FM and they should have you take it back to the yard or they might send you straight to Yoplait.
    Also tell your FM that you want detention.
  6. Hoofbeats
    Hoofbeats Road Train Member
    Jan 27, 2010
    1,250
    Thanks Received:
    1,991
    Iraq
    California isn't the only state with bridge laws.
  7. albert l
    Feb 10, 2013
    1,040
    Thanks Received:
    1,505
    On the Road
    They will open appt at 90 to cover delay, just stress the detention.
    I once had a yogurt load 79990, they may have had a newbie loading the trailer.
  8. shogun
    shogun Road Train Member
    Jan 23, 2009
    6,075
    Thanks Received:
    72,159
    Doing a regen
    You have 1320 available on the drives, you are only over 800 on the tandems. Like STexam said, slide it two or three holes back and you will be legal. Rescale just to be safe.
    FullMetalJacket and SingingWolf Thank this.
  9. albert l
    Feb 10, 2013
    1,040
    Thanks Received:
    1,505
    On the Road
    And ask for extra miles to cover to and from scale
  10. albert l
    Feb 10, 2013
    1,040
    Thanks Received:
    1,505
    On the Road
    He is at maximm length for Indiana and Tennessee
    Toomanybikes and Farmerbob1 Thank this.
