Wrong load numbers again
Discussion in 'Questions From New Drivers' started by Mark_2wain, Mar 13, 2017.
  1. Mark_2wain
    Mark_2wain Light Load Member
    Oct 15, 2016
    141
    Thanks Received:
    94
    Virginia
    So, here i am, arrived 30 min early for a live load and i need to sit and wait until dispatch can get me the right load #. Going to miss my arrival window now. Is this normal in trucking?
    NavigatorWife Thanks this.
  2. Mark Kling
    Mark Kling Technology Contributor
    Sep 23, 2007
    10,935
    Thanks Received:
    4,216
    Statesville, NC
    yes and no... depends on your company and dispatch.
    Next time,,, call the shipper beforehand and verify the load number and pickup date/time...
    less headaches that way.
    Lepton1, Puppage and Just passing by Thank this.
  3. SGIT
    SGIT Light Load Member
    Apr 6, 2015
    246
    Thanks Received:
    905
    West Jordan, UT
    It happens once in a while. Definitely shouldn't be a regular occurrence
  4. Mark_2wain
    Oct 15, 2016
    141
    Thanks Received:
    94
    Virginia
    OK good to know it at least CAN be normal. Just a bit scared that they will try to blame me for being late.
  5. Pedigreed Bulldog
    May 7, 2011
    7,737
    Thanks Received:
    14,422
    Yes. And no. Happens far more often than it SHOULD, but we're all human. Shipper has to give the p/u# to the broker. Broker gives it to the dispatcher. Dispatcher gives it to you. You give it back to the company. Anyone along the way can have a typo, mis-hear, mis-read, or just look at the wrong number on the page when passing along the information.
    Lepton1 Thanks this.
  6. Pedigreed Bulldog
    May 7, 2011
    7,737
    Thanks Received:
    14,422
    The shipper knows you're there, and that you're trying to figure out what the correct #'s are so they can load you properly. They SHOULDN'T hold it against you if you're "late" by the time you get the correct info as long as you had arrived at what would have been "on time".
    Puppage and Mark_2wain Thank this.
  7. SGIT
    Apr 6, 2015
    246
    Thanks Received:
    905
    West Jordan, UT
    Unless it's WalMart...then you're pretty much screwed
  8. Pedigreed Bulldog
    May 7, 2011
    7,737
    Thanks Received:
    14,422
    That all depends on your attitude and timing. Back in my door-slamming days many many moons ago, I had a load to a WM DC somewhere in SC, and I had more than enough time to get there. So much, in fact, that I arrived 3 days early. I approached the guard shack, and politely asked if there was any way I could possibly get unloaded early or if I should go back to the truck stop and sit there for 3 days until my appointment. He made a phone call, and 5 minutes later I was on my way back to get unloaded. Maybe somebody else missed their appointment, or perhaps they just had an open dock, or maybe they were just in a charitable mood and I seemed nice enough...whatever it was, I got to get unloaded so I could get back to making money instead of laying over for 3 days waiting.
    NavigatorWife, Lepton1, tucker and 2 others Thank this.
  9. Boattlebot
    Boattlebot Road Train Member
    Aug 7, 2016
    1,666
    Thanks Received:
    21,079
    I get the wrong number 90% of the time.
    Quick call to dispatch and I get a number that they like. Still annoying tho
    NavigatorWife and passingthru69 Thank this.
  10. Mark Kling
    Sep 23, 2007
    10,935
    Thanks Received:
    4,216
    Statesville, NC
    Or delivering Satellite antenna's to the Atlanta DC... road is only big enough for one truck .... wrong load number, cannot move off, back up, or go forward... so those behind you have to sit...
