I shift check transmission light
Discussion in 'Volvo Forum' started by SWTRANSPORTATION, Aug 15, 2019.
  1. SWTRANSPORTATION
    SWTRANSPORTATION Bobtail Member
    12
    Nov 19, 2018
    Hey guys
    I got check light for Transmission , and fult code SA 24 DTC p107177
    And SA 24 DTC p105594
    The transmission doesn't go up or down shift manual or auto mode
    Sometimes changes , but loses The power in 2.4.6
    Any idea can help please
    Volvo 2015 ,, 590k
    Update , I got this message from technical support
    Your fault code that you have is for split engagement system. There is 2 different internal reduction systems inside the transmission. There is a range and a split system. There are a few different fall backs for the split system. One big thing to check would be to make sure the trans does not have any air leaks when the truck is fully aired up. The splitter is all internal and is commanded on and off by the tcm which is mounting to the top of the control housing. There is multiple test to be ran with a pc in order to move the splitter to see if there is an issue with the position sensor, shift fork, range cone, seals for cylinder inside, and to perform the clutch and internal speed sensor fault. That really is the only way to fully diagnose this fault code. Please let me know if you have any follow up questions on this. Thank you
  3. Rob100100
    Rob100100 Light Load Member
    206
    122
    Mar 5, 2016
    I shifts can only be repaired by the Volvo dealership. You might be able to find a non dealership shop but the I shift would need reprogramming and I would not trust another shop. Take it in and see what it needs unfortunately that is the only choice in the matter really.
    See X- misssion problem
    Jack carg Thanks this.
  4. ast26909
    ast26909 Medium Load Member
    408
    264
    Mar 1, 2018
    Take it to the dealer and bend over, most European vehicles are made this way I myself will never own one.
    Bean Jr. and SWTRANSPORTATION Thank this.
  5. Jack carg
    Jack carg Bobtail Member
    20
    7
    Mar 1, 2019
    Go for the dealer, maybe volvo warranty will cover it , they said 750k for the transmission
  6. jaylo
    jaylo Bobtail Member
    21
    18
    Jan 30, 2010
    wichita,ks
    I would disconnect power to everything big switch behind step door driver side (battery) area... let it sit for at least an hour. It might reset but it has limp mode but also warranty is good.
  7. Jack carg
    20
    7
    Mar 1, 2019
  8. SWTRANSPORTATION
    12
    Nov 19, 2018
    Thanks jaylo
    I disconnected the power from battery for 30m but still the same , its drive only on 1,3,5,7,9,11
    loseng the power in 2,4,6,8,10,12
    And still have this code SA 24 DTC p107177
    Do you think warranty will cover this issue ? , 2015 590k
  9. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Call dealer asap.
    If you keep driving it ,they might void any warranty you have.
  10. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    You have probably a top cover problem or an internal harness problem both require the trans to come down very few shops have capability to work on ishift if you are anywhere near chicago i can take care of it for you. without opening the trans it could be best case scenario $2000 with parts and labor or worst $7000 if something is wrong and i have put on a shortie trans from volvo.
  11. QUALITYTRUCK
    1,821
    1,789
    Jun 14, 2009
    romulus,mi
    Trust me the man knows his sh*& when it comes to Ishift. I send my Ishift customers to him and he yells at me to fix them myself,with his guidance if I need it. LOL!! I think I trust him more than myself.
