‘21 Pete 389 no cruise or engine brake
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jrhd97, Aug 22, 2022.
  1. EricFortin85
    EricFortin85 Bobtail Member
    Jun 5, 2023
    Thanks Received:
    Check fuse D10.
    MISC LOW CURRENT
    Pete 389 2024
    New datch
    Loose CB cruise & jake d-10 is burn
  2. EricFortin85
    Jun 5, 2023
    Thanks Received:
    Check fuse D-10
    MISC LOW CURRENT
    Lost power CB
    Cruise & Jake d-10 was burn
    Pete 389 2024
    New datch
    217flatbedr Thanks this.
  3. 217flatbedr
    217flatbedr Light Load Member
    Jan 20, 2012
    107
    Thanks Received:
    58
    Bringing this issue back to life….
    Just experienced this very issue. 2024 389. Turned out the fuse in position D10 was blown. Replaced fuse all came back to life!!
    Now, the rest of the story…..
    I recently installed an aligned, converted and tuned Stryker 447HPC2. I had to splice the factory jumper power wires with the Stryker provided power wires. I realize the OEM power supply wires are slightly thinner/smaller than the Stryker wires. However I rolled the dice and connected everything. No issues until…..I came across info that using the smallest length of power wire will allow greater watts. Great!! So here’s where things took a turn. I go in and shorten the power wires Stryker sent. I left all inline fuses in place. I hook everything up and boom….no power to cb, cruise stopped working, Jake’s stopped working. Just like the OP stated/experienced. Only difference was I noticed no arching of wires. So I replace D10 fuse. Hook everything back up, turn Stryker on, she works!! Turn Stryker off, Reassemble everything I took apart and turn Stryker back on. NOTHING!!.
    So here’s where I’m at….my guess is the shortened Stryker wires pushed just enough watts to create this issue?. I saved the Stryker wire I removed. Would it be safe/advisable to splice that length of wire back together and see if, in fact the extra watts are just too much hence causing the D10 fuse to pop? At this point I’m just speculating and asking questions (learning). TIA.
  4. dirthaller
    dirthaller Road Train Member
    Sep 22, 2011
    1,109
    Thanks Received:
    12,981
    Coloratah
    There is a switch under your cab that is controlled by the clutch pedal. Probably not related but I over grease my truck and grease drips down on that switch and looses electrical contact to that switch. Something to think about. I’ve replaced that switch twice on my 2014 389.
  5. ducnut
    ducnut Road Train Member
    Dec 31, 2010
    2,587
    Thanks Received:
    7,807
    SPI
    There is a CB sub-forum where you should probably start a thread. There are some very knowledgeable people in there.
    Sub-forum link:
    CB Radio Forum
    Me knowing how sensitive PACCAR’s electronics are and the fact you’re installing something well above the average CB, I’d be running a separate, fused power supply from the battery box. There’s a lugged breaker down there you can tap onto that isolates high-amp draws from the rest of the truck’s electrical systems. My inverter is factory-installed onto that breaker, so it’ll easily handle a high-end CB.
    2Tap and 217flatbedr Thank this.
  6. 217flatbedr
    Jan 20, 2012
    107
    Thanks Received:
    58
    Like you, I probably tend to “over grease” my equipment as well!! Hey, grease is cheap…even THAT grease is CHEAP!!! Anyway I will look into your suggestion. Thanks Brother!!
    dirthaller Thanks this.
  7. 217flatbedr
    Jan 20, 2012
    107
    Thanks Received:
    58
    And here is where and why the interweb has value. Thank you, Sir!!
    ducnut Thanks this.
  8. JonJon78
    JonJon78 Road Train Member
    Jul 1, 2018
    7,207
    Thanks Received:
    42,211
    I don't understand. On my 389, it came with a factory cobra installed, so if your putting in a different CB aren't you just disconnecting the factory CB and installing new using the same wires?
    Why would you or did you install new wiring?
  9. JonJon78
    Jul 1, 2018
    7,207
    Thanks Received:
    42,211
    What switch?
  10. dirthaller
    Sep 22, 2011
    1,109
    Thanks Received:
    12,981
    Coloratah
    The switch that disconnects when you push down clutch pedal. If it isn’t connected, no cruise, no jakes. It disconnects when you barely tap the clutch pedal. If it is dirty, you have no cruise or jakes because the ECM thinks that you have your foot on the clutch pedal.
    Peterbilt Clutch Switch 1604996
    ducnut and JonJon78 Thank this.
  11. 217flatbedr
    Jan 20, 2012
    107
    Thanks Received:
    58
