2016 Volvo with electronically controlled air dryer and governor. Piece of crap!
Discussion in 'Ask An Owner Operator' started by Forever237, Aug 5, 2022.
  1. Mysen1
    Mysen1 Bobtail Member
    Jun 27, 2014
    13
    Thanks Received:
    16
    Also, that brown airline where the governor should have been is probably a shop air connection.Mine leaked so I capped it off.(Try some soapy water there)Truck still has the problem with air bags not being inflated while parked/getting loaded/unloaded until I turn truck parking brake off.Then,after turning parking brake off, the bags will inflate.Mentioned all of this to several Bruckner's, and they all suddenly want to start talking about something else.Nobody has a clue .Hard to find leaks empty, but with 45k in trailer you increase your chances.If you can eliminate all leaks this "no governor"system might work..I think.Dryer is still gonna purge whenever da master brain tells it to.
  2. W923
    W923 Road Train Member
    Feb 28, 2022
    1,387
    Thanks Received:
    4,258
    What compressor does the truck have… just thinking a mechanical d2 governor is around 20 bucks and guaranteed to work if you can connect it to the proper ports on the compressor
  3. AModelCat
    29,390
    Thanks Received:
    161,299
    And Europeans think their trucks are superior because of all the electronic crap like this.
    I spent a brief period of time at a shop that supported a European brand of equipment and any time one showed up I cringed and found a hiding spot somewhere lol.
    Another Canadian driver and W923 Thank this.
  4. Forever237
    Forever237 Light Load Member
    May 29, 2016
    122
    Thanks Received:
    63
    I will ask mechanic on Monday when they open. I doubt there is a port for governor. I talked to him yesterday to see if I could switch to bendix air system instead. He said it is a big headache and not because of all the plumbing, but the ecm or whatever chip is responsible might go nuts. He said he will talk to a software guy on Wednesday to see if its possible to trick it. We’ll see.
  5. Forever237
    May 29, 2016
    122
    Thanks Received:
    63
    What if I install “regular Volvo” governor on that line? Do you think it might work?
  6. W923
    Feb 28, 2022
    1,387
    Thanks Received:
    4,258
    I would think..but I don’t know, that as long as the pressure is in range and the volvo pos dryer and governor are still electricly connected that it will be fine.
    As far as a decompression port to use a regular governor idk But I would almost be surprised if it’s not there
  7. 86scotty
    86scotty Road Train Member
    Aug 27, 2017
    4,632
    Thanks Received:
    12,605
    Appalachia
    Weird, mine has one there. Nearly a million miles and never a problem with the air governor/dryer system except a couple of cracked manifolds (leaks). Both were typical, the one through the firewall and the one inside driver's frame rail by trans.
  8. Forever237
    May 29, 2016
    122
    Thanks Received:
    63
    I’m looking into that theory about airbags. Mine fails only when i’m hooked to the trailer and I went to mechanics bobtailing.
  9. Jacoooooooo
    Jacoooooooo Heavy Load Member
    Oct 20, 2013
    748
    Thanks Received:
    1,054
    No because there are no air lines or they are routed elsewhere - the ones that normally connect to the governor. One would need to compare schematics of both systems to figure it out.
  10. MWTechGuy
    MWTechGuy Bobtail Member
    Nov 8, 2022
    17
    Thanks Received:
    6
    A little late to the game here but there are 2 main things with these dryers 1) Volvo had a recall involving engine reprogramming for air over-pressurizing. (Reprogrammed ECM and replaced Cartridge as the overpressure caused cartridges to get saturated and could cause the air dryer solenoids to fail) Volvo FSB5610991. 2) WABCO had a testing process for the solenoid/s TP-1474. Hope that points you in the right direction...
