2ndary air tank not filling up quickly
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Feb 21, 2018.
  1. mitmaks
    mitmaks Road Train Member
    May 16, 2014
    2,564
    Thanks Received:
    2,077
    Whenever my truck is parked for a couple of days I come back to empty air tanks and when I start it up it will fill up primary tank fairly quick and sometimes it won't start filling up 2ndary tank for several minutes, especially when its cold (in single digits) is there crossover that might be frozen over or what should I look at to diagnose the problem.
  2. magoo68
    magoo68 Road Train Member
    Jun 11, 2011
    3,393
    Thanks Received:
    5,385
    st malo mb canada
    Check valve between the tanks to preserve brake air in primary tank is gummed up or partially frozen .. ps it always fills the primary to 90 or so before valve opens to let air into secondary tank
  3. mitmaks
    May 16, 2014
    2,564
    Thanks Received:
    2,077
    I do drain tanks and there's no moisture that I've noticed ever. Wondering if there's way to pour some of that brake line conditioner into the tanks.
  4. magoo68
    Jun 11, 2011
    3,393
    Thanks Received:
    5,385
    st malo mb canada
    Some guys remove the line off the compressor and fill it up .. I haven't needed to do that so can't say how hard or easy that is
  5. mitmaks
    May 16, 2014
    2,564
    Thanks Received:
    2,077
    Are there removeable bolts/fill holes on top of tanks?
  6. spsauerland
    spsauerland Road Train Member
    May 31, 2010
    4,296
    Thanks Received:
    10,889
    West Harrison, In
    If it has an ADIS air dryer, secondary does not build until primary is around 106 PSI. Normal operation for that dryer.
    SAR, GrapeApe, Heavyd and 1 other person Thank this.
