3rd Decimal on Fuel Quantity Missing on Fuel Reports?
Discussion in 'Ask An Owner Operator' started by PE_T, Apr 18, 2019.
  1. Ezrider_48501
    Apr 2, 2011
    3,845
    Thanks Received:
    5,130
    bismarck, nd
    if you want to add more tin foil to your hat only fuel at night or in the early morning hours. fuel stations buy there fuel in net gallons witch accounts for thermal expansion and contraction of the fuel. but yet the pumps are only capable of measuring gross gallons.
    if you were to 10,000 gallons of fuel that was at 30*F would be 10,207 net gallons of fuel
    the same 10,000 gallons would only be 9,790 net gallons at 90*f
    granted most fuel stations have in ground tanks and net is corrected to volume at 60* f and depending on the depth and the region the tanks are buried the ground should somewhat regulate the fuel to somewhere around there, of course they could have just dumped a hot load in those tanks that has been in the sun on a 100 degree day all day or a cold load in the winter. there are also stations that use above ground tanks where you are probably more likely to see a larger swing in fuel temperature. again not enough to worry about but its on the same level of the rounding of the thousandths of a gallon that your worried about.
    if your that worried about it when your done fueling bump the trigger a couple times till your at .xx4 and really stick it to em.
  2. PE_T
    PE_T Road Train Member
    Jul 12, 2017
    3,412
    Thanks Received:
    3,788
    Texas (trucking since 02/2013)
    And you’re still pulling a straw man fallacy. I already explained that I don’t care about the pennies. How else could I explain it to you? Take off that tin foil hat, and pay attention. I repeat, the issue I brought up in this thread wasn’t the pennies we may be losing—but instead the possibility that they are stealing from us. The amount doesn’t matter. The possibility of theft is what I am talking about.
  3. Ezrider_48501
    Apr 2, 2011
    3,845
    Thanks Received:
    5,130
    bismarck, nd
    no one is stealing your .001 of a gallon they are just simply rounding it up or down to the nearest hundredth of a gallon. even if they rounded from .001 to .010 witch isn't how rounding works and you had a fuel transaction every single day for a year 365 days it would add up to roughly $1.095 witch would round up to $1.10 btw its not some big conspiracy theory your the one grasping at straws. this thread is just silly like i said if your that concerned about it make sure that your fuel transaction always ends in a fuel quantity that rounds in your favor so you can "steal" from them.
    edit to add
    btw its really easy to make sure that they are rounding fairly by comparing your fuel report to the receipts that you collect when you pump your fuel.
  4. RedForeman
    RedForeman Momentum Conservationist
    Jan 30, 2011
    4,875
    Thanks Received:
    22,141
    Does the price on your EFS statement match what is printed on your fuel receipt from the store (less any correct discounts)? Rounding off the thousandth of a gallon on your fuel card transaction report doesn't change the sale price at the pump.
    You're also worried about fuel surcharge in states like KY and VA. That's based on miles and your quarterly average mpg. If you think you're being ripped off there, all you have to do is record your precise fuel quantities separately or use your store receipts to get your state gallons correct to 6 digits and compare with the rounded figure off your EFS report. I would estimate the difference across an entire quarter might be a penny or two either way. But that's nothing EFS benefits from. It's a tax paid to a state based on EFS numbers.
    Besides, anyone that stops the pump on an even quantity is foolish. You should make it stop on a random prime number. Anything else is just unlucky.
  5. PE_T
    Jul 12, 2017
    3,412
    Thanks Received:
    3,788
    I just finished comparing my fuel receipts with my Fleet One fuel reports, and the rounding is done correctly. 0.005 goes to 0.01, and 0.004 goes to 0.00. Also, the math calculations are done with numbers in the 3rd decimal. It would be bad if they actually did the math with rounded numbers.
    I think they should have left the numbers in the fuel reports without rounding them. Now the numbers don’t add up correctly. For example,
    Fuel report
    100.820 gallons
    3.159 price
    318.50 total price
    However, when you add both you get:
    100.820 x 3.159 = 318.49
    Pump fuel receipt
    100.823 gallons (with 3rd decimal)
    3.159 price
    318.50 total price
    So ultimately I did not find anything wrong. The reports may show some rounded numbers, but the math calculations were done with complete numbers and not rounded numbers.
    P.S.
    @Ezrider_48501
    I can now finally go to sleep. The amount of money I could have lost would have certainly left me homeless. :D:p
  6. RedForeman
    Jan 30, 2011
    4,875
    Thanks Received:
    22,141
    That was exactly my point. EFS isn't doing the math, the fuel pump is. EFS is only rounding the gallons reported, and they aren't the ones calculating the sale price. Call or email EFS support and ask them why they're doing that would be my suggestion.
    For what it's worth, my FleetOne card went to EFS last quarter too, I just haven't run my reports to make that rounding discovery yet.
    Also, when I enter my IFTA values in the Georgia DOR web return, gallons must be entered with no decimal. So I use the rounding function in my spreadsheet, although the math is done with the actual values. When the sum is off by a gallon, i just add a gallon to a low tax state like SC, or subtract a gallon from a high tax state like PA and force balance it. Using those choices means I'm not making a change that's favorable to me, so less likely to raise any red flags at an audit. In either case the difference is a few cents at most. The DOR auditors don't care about that. They are looking for deliberate fraud or incompetency, not rounding errors.
    Speaking of which, I did get an IFTA/IRP audit about 3 yrs ago. Lets just say my methods of coming up with those numbers changed a little across the three years being reviewed. I was able to walk the auditor through my methods and raw data, and he was satisfied with the returns that were reviewed. I passed the audit with no discrepancies found.
    PE_T Thanks this.
  7. PE_T
    Jul 12, 2017
    3,412
    Thanks Received:
    3,788
    I don’t deliberately avoid IN, KY, or VA for their fuel surcharge. It just so happens that those states don’t have the cheapest fuel along my routes. However, just recently, I noticed I fueled in IN a couple times. I also realized they got rid of their fuel surcharge for diesel.
    To my knowledge, the fuel surcharge in IN, KY, and VA is only applied if you fuel in their state. If you don’t fuel there, you only pay their IFTA fuel tax. That is the reason why it’s recommended to not remove the fuel surcharge from those three states whenever you’re comparing fuel prices. NASTC fuel program does this when displaying the fuel prices for those three states. If I remember correctly, the host of TruckingWithAuthority has also mentioned it.
    Reason for edit: Spelling
  8. RedForeman
    Jan 30, 2011
    4,875
    Thanks Received:
    22,141
    That's not correct. The surcharge is on the calculated gallons used in the state, based on your miles and quarterly average mpg, not tax paid (purchased) gallons. If you drove in a surcharge state, you'll pay that tax regardless if you bought any fuel there.
    Since there is no way to correlate the state mileage you might run to a per gallon rate, NASTC is doing the only thing possible which is to leave it off. Only you can estimate that added cost with a prediction of how many miles you expect to run there. For expense projections, it would probably work better to figure that surcharge as a cost per mile to operate in that state versus a fuel tax line item due to how it works. Don't confuse the fact that this tax has the word "fuel" in it to necessarily mean that it inflates the cost of fuel. It's a calculated value collected on your IFTA return, not an amount added to the price of fuel at a pump.
    Contrast that to how NASTC includes sales taxes in the net cost in states where it is included in the pump price (Georgia, New York, California, and two more I can't think of at the moment). You have to pump fuel in the state to pay it, so it's simple to include that in the net cost per gallon. You can avoid that tax by not purchasing fuel in those states.
    PE_T Thanks this.
