A little help with this question.
Discussion in 'Trucking Schools and CDL Training Forum' started by otterinthewater, Jun 21, 2018.
  1. otterinthewater
    May 10, 2018
    5,549
    Thanks Received:
    29,152
    Santa Barbara, Ca
    Ummmmmmmmmmm...
    bigmotor1212 Thanks this.
  2. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    Mar 9, 2014
    3,982
    Thanks Received:
    18,764
    In a van down by the River.
    A or B. But really you should back under till the 5th wheel disappears. Stop, get out, make sure 5th is flat and not at an angle, then back underneath and do a or b.
    Lav-25 Thanks this.
  3. otterinthewater
    May 10, 2018
    5,549
    Thanks Received:
    29,152
    Santa Barbara, Ca
    Thanks for the answer.
    I understand the procedure, but only A or B is correct. It’s the same answer. So you have to randomly guess. Glitch.
    I read it and laughed.
  4. CrappieJunkie
    Mar 9, 2014
    3,982
    Thanks Received:
    18,764
    Yeah, I'd say a glitch.
  5. Oldironfan
    Oldironfan Road Train Member
    May 22, 2017
    5,777
    Thanks Received:
    5,543
    Well first off your supposed to check to make sure king pin is locked in place and jaws are locked. Than proceed with tug test. And I never look back after tug test unless my trailer tandems are dragging.
    Lav-25 Thanks this.
  6. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    Mar 19, 2018
    3,740
    Thanks Received:
    5,740
    Nashville
    I tug first because I am already there. If it holds, I Check the pin when I do the landing gear.
    x1Heavy and bigmotor1212 Thank this.
  7. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,017
    Thanks Received:
    42,137
    White County, Arkansas
    I pull until trailer skids just a little. Then set tractor.
    Crawl under there and eyeball that big U joint, handle, spring etc. Everything should be in place.
    No matter what or how rushed I am I always recheck that #### thing before getting in.
    Lav-25 and tinytim Thank this.
  8. otterinthewater
    May 10, 2018
    5,549
    Thanks Received:
    29,152
    Santa Barbara, Ca
    Ok everyone. Thanks for the schooling, but I thought my humor would show up.
    There’s the exact same answer, but one is right, and one is wrong. You don’t know if it’s A or B.
    It made me laugh.
    BTW the timed tests are excellent. I really like taking them over and over!
  9. Lab work
    Lab work Medium Load Member
    Apr 20, 2018
    551
    Thanks Received:
    674
    USA
    Can you ask the examiner how many people picked D?
    otterinthewater Thanks this.
  10. otterinthewater
    May 10, 2018
    5,549
    Thanks Received:
    29,152
    Santa Barbara, Ca
    I’m scared to ask.
