A lot of oil coming out of air tanks and purge valve need help .
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Nestor, Mar 1, 2018.
  1. Superhauler
    Superhauler TEACHER OF MEN
    Jan 30, 2010
    12,209
    Thanks Received:
    100,730
    keep stroking.
    That's not what I mean. The extra air pressure from the boost of engine feeds the air comp. Putting more pressure in the cylinders of air comp. When you took the line off that runs from side of engine head to intake of comp was it saturated with oil?
    SAR, BoxCarKidd and Nestor Thank this.
  2. 062
    062 Road Train Member
    Oct 20, 2013
    6,204
    Thanks Received:
    33,430
    The truck I have now was passing oil when I bought it,changed filters and stopped passing oil. You can't rely on the restriction gauge,have to look at them to see if they are dirty.
    BoxCarKidd Thanks this.
  3. spsauerland
    spsauerland Road Train Member
    May 31, 2010
    4,296
    Thanks Received:
    10,887
    West Harrison, In
    Here's the manual to follow to estimate oil consumption per Bendix
    SAR and Dave_in_AZ Thank this.
  4. Superhauler
    Jan 30, 2010
    12,209
    Thanks Received:
    100,730
    keep stroking.
    There will ALWAYS be a little discharge of oil. It is normal. When it gets where your air dryer is spewing oil that is excesive.
    SAR and spsauerland Thank this.
  5. Nestor
    Nestor Light Load Member
    Oct 21, 2015
    160
    Thanks Received:
    23
    I took it off from compressor side . It wasn’t wet but I can tell oil been in there. The other end of that line that goes into engine is all full of oil like if it’s been seeping out.
    Also a line on the air governer is all gunked up in oil also
  6. Nestor
    Oct 21, 2015
    160
    Thanks Received:
    23
    Yes that’s what’s happening airbdryer is all gunked up and also the foot valve is too from the exhaust port . Also discharge braided hose is Also gunked up but where it connects underneath cab
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    Aug 26, 2014
    4,467
    Thanks Received:
    6,504
    I have a 388 here doing that. Did you get yours straightened out and what was the problem?
  8. McMahons Trucking
    McMahons Trucking Light Load Member
    Jul 4, 2018
    274
    Thanks Received:
    119
    I know this is an older thread. I just replaced my 3406 and need to attempt getting the oil out of the air system. I replaced the air cartridge and cleaned the air dryer out really well. What about the air lines and tanks? Can I dump a bunch of air line antifreeze down the hose and pressurize, drain the tanks and repeat?
  9. BoxCarKidd
    Aug 26, 2014
    4,467
    Thanks Received:
    6,504
    Just changed the compressor and serviced dryer. They all worked out OK.
