Anti idiling requirements and equipment
Discussion in 'Ask An Owner Operator' started by issiah53, Aug 6, 2010.
  1. issiah53
    issiah53 Bobtail Member
    Jun 16, 2010
    6
    Thanks Received:
    Ranger.GA
    With more & more states coming on line with anti-idling laws, I have to make a choice of equipment. I really like the ComfortPro from Carrier but the cost is $8,000.00 +. I have heard of a Canadian Company that uses the truck's batteries to power a wall mount A/C unit. The company's name is Cool Moves. Does anybody have any comment on this company and their equipment?:biggrin_25515:
  2. Krooser
    Krooser Road Train Member
    Jul 25, 2010
    2,493
    Thanks Received:
    1,066
    Wisconsin
    Seven grand...apu's are expensive.
    I have an espar heater and I'm going to try a swamp cooler for $500.00
  3. Krooser
    Jul 25, 2010
    2,493
    Thanks Received:
    1,066
    Wisconsin
    That's 7k installed... put it in yourself and save.
  4. mleibelt
    mleibelt Light Load Member
    Feb 25, 2010
    63
    Thanks Received:
    24
    Friendship, WI
    I have a 2000 watt Honda in the back deck...I floor A/C unit with the hose out the window using an old Idle Air window adapter...Honda was 900 bucks and is CARB approved...A/C was 200 bucks...Freezes my ##### off and uses about a gallon of gas in 10 hours...Works for my and payback is quick....
    Cropduster Thanks this.
  5. mslashbar
    mslashbar Medium Load Member
    Jul 22, 2009
    604
    Thanks Received:
    822
    elizabeth,co
    Can you tell me a little more about your a/c unit and how you have it installed. Thanks in advance.
  6. YankeeTexan
    YankeeTexan Light Load Member
    Jan 1, 2009
    222
    Thanks Received:
    194
    Houston, Tx
    We are kindred spirits. I have the same thing. my little 2k honda generator and a floor mount ac (I did take out the pass seat and put a/c in its place) and instead of a Idle air thing I just used a piece of 1x4 and a saw and custom made my window adapter. Plus in the fall, winter and spring I leave the ac at home and just use the gen for power to run the tv, sat receiver, computer etc. I keep mine in my tool box and just take it out and chain it to the frame with a lock at night. (I run tanker and have pump and hose rack on my back deck so there is not any room there). Plus i get a little exercise walking up to the gas pumps to fill my little gas can when i do the set up. Takes a few min to set everything up but, once you get the routine down it goes pretty quick and the cost savings more then makes up for any issues. Plus the maint on the little gen is quick and cheap. replace the spark plug once a year, rinse out the air filter and change the oil every month or so (only takes 3/4 quart and takes about 30 sec to change). Total investment about $1200 or so. A whole lot better then the 7-8K for an "regular" APU.
  7. rollin coal
    rollin coal Road Train Member
    Mar 29, 2008
    13,640
    Thanks Received:
    28,040
    TN
    Some states have grants to help defray the cost of installing an apu. I don't know about GA but in TN you can get half of your money back up to a certain amount like $7,000 or $8,000 I think. I'm a little fuzzy on what that $$$ limit is but certain they do give money back. My truck already had one when I bought it or I'd take adavantage of this. You might want to dig around on OOIDA's website for more information about what different incentives states offer to truck owners for installing anti-idling equipment.
  8. MeatHead
    MeatHead Medium Load Member
    Sep 25, 2009
    327
    Thanks Received:
    115
    I'm curious why you would run your generator to run the tv, sat and computer instead of using an inverter? Your batteries should have no problem powering all those items and then having your truck charge the batteries the next day. I can see running the generator for the A/C in the summer.
