Can I be sucessfull O/O with power only?
Discussion in 'Questions From New Drivers' started by ggtrucking12345, Apr 9, 2021.
  1. ggtrucking12345
    ggtrucking12345 Bobtail Member
    Apr 9, 2021
    9
    Thanks Received:
    11
    Probably asked a lot but I haven't seen it much. What kind of numbers could a team do running PO off of Convoy/Amazon and such and possibly renting a trailer when spot market is hot for dry van?
  2. Ridgeline
    22,400
    Thanks Received:
    116,456
    Yes. FedEx .... power only
  3. 86scotty
    86scotty Road Train Member
    Aug 27, 2017
    4,474
    Thanks Received:
    12,010
    Appalachia
    I'd say it would depend on your location.
  4. ggtrucking12345
    Apr 9, 2021
    9
    Thanks Received:
    11
    I see they have multiple divisions? I'm assuming they are all different do you have any suggestion which ones to check out? The company drivers haul all the ground freight right?
    Ty
  5. ggtrucking12345
    Apr 9, 2021
    9
    Thanks Received:
    11
    We are in Jacksonville... My teammate and I want to run regional and get more home time but aren't opposed going to other areas providing better pay and we can make it home. The way I'm looking at it is running to either Texas/Tennesee, another leg, then back home and trying to repeat or pickup extra loads throughout the remainder of the week. We aren't looking for 6k+ miles the whole reason we will do teams is so we can get our miles in quicker and get home.
  6. slow.rider
    slow.rider Road Train Member
    Apr 4, 2017
    2,005
    Thanks Received:
    4,740
    NYC
    Landstar is no good?
  7. Judge
    13,299
    Thanks Received:
    87,768
    Landstar Bad.
    Go to Schneider.
  8. jmz
    jmz Road Train Member
    Mar 9, 2018
    1,171
    Thanks Received:
    2,769
    Great Plains
    Freight and Express are all company drivers, but Freight does use power only in some lanes. Ground only uses independent contractors, so that could be an option if they have any open team slots in your area.
  9. jason6541
    jason6541 Road Train Member
    Mar 5, 2012
    2,425
    Thanks Received:
    5,366
    Omaha, NE
    Power only be prepared for long hops bobtail between jobs. Nothing consistent
    You can do it but not be home on a regular basis. Unless you find some private companies that just need trl’s moved from facility to facility
    slow.rider Thanks this.
  10. bonder45
    bonder45 Road Train Member
    Oct 2, 2011
    1,803
    Thanks Received:
    5,450
    Williston, ND
    You’d have a good chance if you picked up 3-4 different carriers.
    Say run FedEx from home to another terminal, jump on Amazon and move a trailer to a different town. Look at both to see if there is anything back and if not hit up a load board and grab a PO load.
    If you really focus you should be able to do pretty good.
