change Steers from lopro to 11r22.5. issues?
Discussion in 'Ask An Owner Operator' started by Elroythekid, Jan 1, 2019.
  1. Elroythekid
    Elroythekid Road Train Member
    Sep 9, 2010
    2,608
    Thanks Received:
    5,663
    Halifax Nova Scotia
    I have lopro 22.5 all around on my Columbia glider. The steers have wear issues nobody and no alignment seems to be able to solve. I would like to try a set of 11r 16ply and run higher pressures and see if I can get rid of the issue. I upped the pressures to 115 in the lopro and it seemed to slow the wear patterns but the lopro's ride is rough like that. I'm hoping with 11r I'll get a little ride back.
    Any issues running 11r on steers and lopro drives?
  2. DUNE-T
    DUNE-T Road Train Member
    May 10, 2015
    6,973
    Thanks Received:
    16,921
    Detroit, MI
    There will be no issues
    Elroythekid Thanks this.
  3. magoo68
    magoo68 Road Train Member
    Jun 11, 2011
    3,393
    Thanks Received:
    5,385
    st malo mb canada
    You ever get by Drummondville pq ?? I had a cascadia I fought steer tire wear for years I got a alignment done at frieghtliner in Drummondville and tires wore even after that.. mind you that was 4 years ago and things could’ve changed
  4. mpd240
    mpd240 Road Train Member
    Sep 17, 2011
    1,540
    Thanks Received:
    3,625
    Minnesota
    I've always had issues with steer tires. Tire shop guy who did alignments said it was due to trailers not tracking true. Truck is always having to correct fit it. Causes steer tire wear.
  5. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,017
    Thanks Received:
    42,137
    White County, Arkansas
    We never ran low anything on the front end. We ran pretty much the best on the market up there with some beef on them. The steers are the two most important tires. They are going to take some hits so they need to be big and strong.
  6. 25(2)+2
    Sep 18, 2006
    18,751
    Thanks Received:
    45,539
    the road less travelled
    Raise the weight rating a bit, I drove a 93 FLD with larger diameter tires on the front, I can't remember whether they were 22.5 or 24.5 though it looked obvious.
    The tires from the factory on the truck that just went back to the lease company were not seated correctly on the rims. The worst set I had for wear.
    x1Heavy Thanks this.
  7. Spyro2112
    Spyro2112 Medium Load Member
    Mar 17, 2018
    604
    Thanks Received:
    416
    Centramics
  8. x1Heavy
    Mar 5, 2016
    34,017
    Thanks Received:
    42,137
    Ya know, if you had pictures of the treads and so on perhaps some of us can eyeball the things off your steers and see what's what. Talking is one thing. Pictures is really knowing on sight.
  9. Elroythekid
    Sep 9, 2010
    2,608
    Thanks Received:
    5,663
    Halifax Nova Scotia
    It is hard to see. This is when it started.
    The out side edge wears but only about 1/3 of the circumference of the tire. You can see 2 black lines from a marker, about noon and 5 o'clock. It starts and ends with those lines. This was early, I flipped the tire, the Michelin rep took pics etc, he didn't have any answers. It worn both shoulders now and has a river wear patten. I upped the pressure and it "seemed" to slow it down. 20180807_103333.jpg 20180807_103333.jpg
    blairandgretchen Thanks this.
  10. blairandgretchen
    Dec 9, 2011
    13,409
    Thanks Received:
    72,192
    South west Missouri
    I highly recommend Chad in KC for alignment issues - he inspects first and won’t align till you come back with the mechanical issues solved first.
    Doesn’t like to see you back after he’s satisfied with his alignment.
    Solved all issues on my T2000, and now my ‘95 379.
