Cooling fan running all the time
Discussion in 'International Forum' started by njwoods, Sep 8, 2013.
  1. njwoods
    njwoods Bobtail Member
    Sep 8, 2013
    25
    Thanks Received:
    5
    Have an '05 Cat C13 in a 2006 Intl 9200. We've changed the entire a/c system due to multiple parts failures. Two days later, the cooling fan stays on all the time. Fan hub is 3 months old, so they changed the fan solenoid. Good for 2 hours. ANy thoughts?
    I'm thinking maybe the relay behind the fan solenoid. Other than that - insane ecm?
    13 speed eaton, avg 40k loads, 65mph @ 1425rpm, 6.2mpg avg with fan on constantly, running @ 180 degrees
  2. baha
    baha Road Train Member
    Jul 25, 2013
    4,137
    Thanks Received:
    2,837
    ga
    did it stop after the changed solenoid 4 a time
  3. Roadrealtor
    Roadrealtor Road Train Member
    Aug 7, 2010
    1,061
    Thanks Received:
    1,070
    Fort Myers, FL
    Had a Pro Star that did that. Pulled into rest area, turned off the motor to reset the computer, fixed. Happened very very randomly. By your description, doesn't sound like my fix will work.
  4. njwoods
    Sep 8, 2013
    25
    Thanks Received:
    5
    stopped for 2 hours, been on since (10 days)
  5. njwoods
    Sep 8, 2013
    25
    Thanks Received:
    5
    motors been off for long stretches (prefer to sleep in quiet), so i guess no reset - also, no fault codes
  6. G/MAN
    G/MAN Road Train Member
    Sep 3, 2010
    7,031
    Thanks Received:
    8,625
    Have you checked to see if you fan is set to "on" or "auto?" Not trying to be smart, but I have bumped my fan switch with my knee while entering or exiting my truck and was not aware that I bumped it. If the switch is set to "on" it will run all the time.
  7. njwoods
    Sep 8, 2013
    25
    Thanks Received:
    5
    one of the first things i thought of checking. my fan override lives in the top row hidden by the radio & the sirius radio
  8. baha
    Jul 25, 2013
    4,137
    Thanks Received:
    2,837
    ga
    ck. 4 bad con. at plug near firewall unplug look inside. key on should nave power
  9. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,829
    Thanks Received:
    6,280
    If you jump 12 volts to the fan solenoid, and/or, put shop air the fan clutch, does the fan physically disengage? If you have a faulty a/c high pressure signal going to the ECM the fan will turn on seconds after start up, but there should be a brief time period after start up the fan is disengaged before this.
  10. njwoods
    Sep 8, 2013
    25
    Thanks Received:
    5
    connections around solenoid clean and live
