detroit series 60 12.7 engine components
Discussion in 'Trucker Forum Classifieds & Trading Post' started by flatout99, Sep 27, 2011.
  1. flatout99
    flatout99 Bobtail Member
    Aug 17, 2011
    12
    Thanks Received:
    greeley,colorado
    Hi, I will be having very soon, multiple engine parts for sale from a running '99 Detroit s60. Bull gear, head, rocker assembly, Jacobs brakes, intake, camshaft,crank, connecting rods, etc.. If interested send a message with your contact info! Thanks!
  2. flatout99
    Aug 17, 2011
    12
    Thanks Received:
    greeley,colorado
  3. Flightline
    Flightline Road Train Member
    Oct 1, 2011
    2,345
    Thanks Received:
    1,167
    Almost There
    How many miles on the engine and what went bad making you part it out?
  4. flatout99
    Aug 17, 2011
    12
    Thanks Received:
    greeley,colorado
    Piston came apart, piece of the liner fell and got pinched between the crank and block. Damaged the block, not the crankshaft. Have 500 hp head,jakes,rockers,cam,crank,pistons and rods (the ones still intact),bull gear and case, acc. drive gears,pulley drives, valve cover, intake and exhaust manifolds, some injector cores for 500hp, some for 470hp. oil cooler, flywheel, maybe an a/c compressor core and alternator core.....It was running when i turned off the key. I've been told the block is repairable, I didn't have time for that.
  5. flatout99
    Aug 17, 2011
    12
    Thanks Received:
    greeley,colorado
    Oh, there was approx. 300,000 mi. on the head and cam, 10,000 on oil pump. Unknown on the rest but the bull gear has no broken teeth and is thought to have been recently replaced due to not much wear. I can send photos if needed! Thanks!
  6. Dino1968
    Dino1968 Light Load Member
    Sep 22, 2011
    181
    Thanks Received:
    64
    IN MY _ If I tell ya I gotta killya
    I'm looking for Model 790 Jake brake if that's what you have what's your price.Also would be interested in valve cover if new style, which would be be the one that has boltholes around the outside edges.
  7. flatout99
    Aug 17, 2011
    12
    Thanks Received:
    greeley,colorado
    I'll take a look,and let you know today!
  8. flatout99
    Aug 17, 2011
    12
    Thanks Received:
    greeley,colorado
    Dino, My Jakes are model 770, And old style valve cover too... Sorry!:(
